ECU "Not Ready" codes
Old Nov 9, 2009 | 02:29 PM
EK9B18's Avatar
My scanner tells me exactly what things are left to set too. In VA, you can pay $10 to get a 1 month extension on your registration to allow readiness to become active.
Old Nov 9, 2009 | 05:16 PM
Sartis's Avatar
I found it, just to have the information here on s2ki.
Catalytic Readiness
Enable Criteria:
ECT (Coolant) at 158*F or higher.
IAT at 20*F or higher
Vehicle speed is steady, and speed sensor reads more than 25mph
Procedure:
Test drive car under stop & go conditions with short periods of steady cruise. After 5 miles the readiness code should be complete.
Evaporative Emissions Readiness
Enable Criteria:
At engine start up, ECT and IAT are higher than 32*F but lower than 95*F
At engine start up, ECT and IAT are within 12*F of each other
Procedure:
Test drive car under stop & go conditions with short periods of steady cruise. After 2.5 miles the readiness code should be complete.
Old Nov 9, 2009 | 08:52 PM
CKit's Avatar
Catalytic Readiness
Enable Criteria:
Procedure:
Enable Criteria:
Procedure:
That's not all of it.
Old Nov 9, 2009 | 08:57 PM
CKit's Avatar
Page 261-262 of an AP1 manual:
Abbreviated version:
Start engine
Idle 20 seconds
Keep neutral
Increase to 2k rpms and hold for ~3 minutes.
Drive 50-60mph in 5th gear
Drive 90 seconds without moving throttle position.
Coast for several seconds without using the accelerator or brake.
scottusa
Jan 18, 2013 12:11 AM
ce-ce
Dec 10, 2009 11:16 AM
doctor matt
May 23, 2009 02:38 PM
HighwayStar
Jul 5, 2008 01:32 PM
tflpunk
Mar 19, 2008 03:29 PM
