ECU Reset Mod?
Old Nov 7, 2001 | 09:46 AM
Tanqueray's Avatar
Default ECU Reset Mod?
Has anyone figured out an easy way to manually reset the ECU without disconnecting the battery? I am thinking of the push-button reset mods done on other Hondas or something similar.
Thanks,
Tanq
Old Nov 7, 2001 | 10:29 AM
Tedster's Avatar
Yeah, there's a fuse you can pull. Check the FAQ General Maintenance: Resetting ECU/Check Engine Light.
Ted
Old Nov 7, 2001 | 11:14 AM
MacGyver's Avatar
Look at the fusebox under the dash....far right side, 2nd fuse from top (3rd slot, 7.5A). Pull it, wait a few seconds, replace it....you're ready to rock.
Old Nov 7, 2001 | 12:28 PM
marcucci's Avatar
Check out:
http://www.ntpog.org/mods/fifth-afc/ecu.shtml
for a "permanent" one. I can't vouch that the wire is the same (probably isn't), but if you email or PM me I can look it up and tell you which one it is.
Old Nov 7, 2001 | 09:32 PM
DSF_S2k's Avatar
On the ECU..
Connector B 25 pin (middle gray connector) pin 21 White/Red (VBU) Power source for memory.
Requires a Normaly closed switch inline. Open will reset the ECU.
Dale
jts09
Aug 11, 2018 08:50 AM
run115
Jan 20, 2009 11:34 AM
HighwayStar
Nov 20, 2007 06:00 AM
Cheese Steak Nazi
Oct 17, 2007 07:00 AM
micron1
May 31, 2007 10:15 PM
