Eibach's sitting higher on one side?
Old Feb 15, 2006 | 12:17 AM
Kschmied's Avatar
Default Eibach's sitting higher on one side?
Got a question S2kI. I put on my Eibach pro kit about 8 days ago. I made absolutley sure to pre-load each corner the same and correct way, torque every nut to spec, and seat the springs on the (stock) struts correctly, but somehow.. my passenger side is noticable lower in both front AND rear then the driver side. I would LOVE it if the passenger side was as high as the driver side ( about 1" lower ), but theres barley a single finger gap in the front and its causing rubbing problems I also made sure to put the front springs in front and rear springs in rear. Is there anything I can do to fix this problem? Any suggestions? Thanks!
Old Feb 15, 2006 | 08:40 AM
SIIK2NR's Avatar
Shock could be blown...
Just a thought.
Old Feb 15, 2006 | 08:52 AM
Irace4Kimchi's Avatar
what the...
i had my eibach on my ap1 and i had about 2finger gap on front. rear was little lower than front.
i had eibach w/ 225/45/17 tires on them. (front)
Old Feb 15, 2006 | 09:11 AM
RED MX5's Avatar
[QUOTE=Kschmied,Feb 15 2006, 04:17 AM]Got a question S2kI.
Old Feb 15, 2006 | 09:12 AM
Silver9k's Avatar
It sounds like SOMETHING had to have gone wrong durring the installation, I don't know what, but double and triple check everything...its probably some minor detail, and that why that detail was there.
Old Feb 15, 2006 | 11:00 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Eibach are known for that.
Old Feb 15, 2006 | 12:56 PM
crono's Avatar
I just installed my springs last week. At first it seemed like my front passenger side was higher than the driver's side and my rear driver's side was higher than the passenger's side. After a week of letting them settle, it got better but not by much. So I thought it could be tire pressures. When I went to go fill up my tires on some air, they were all sitting correctly. It seems like the very slight incline of my driveway was the problem. It might be a silly idea, but it may be the same reason for you. That and the tire pressure thing.
Old Feb 15, 2006 | 04:22 PM
RED MX5's Avatar
Known for what?
Old Feb 15, 2006 | 06:04 PM
i2ichal2d's Avatar
maybbe u got two rears on one side and two fronts on the other
Old Feb 15, 2006 | 06:05 PM
stitos2k's Avatar
You didn't put both fronts on one side and both back's on the other did you
