Eibach's sitting higher on one side?
Originally Posted by stitos2k,Feb 15 2006, 09:05 PM
You didn't put both fronts on one side and both back's on the other did you
just jacked it up and checked it out a few minutes ago. Both the front springs end in serial number 01 ( front ) and both the rear springs end in 02 ( rear ). All four springs are seated against the strut mount exactley as they should be... leaving the ONLY thing that i could think it would be is the pre-load on the front driver side... but I KNOW i pre-loaded it the exact same way I did all the other corners. ALSO, i found out ( through measuring ) that BOTH rear's are the same drop. It just looked different because the front passenger side is lower. So the ONLY problem now, is that either the driver side front is too high ( i hope not... its about as low as I want to go ) or the passenger side is too low.
im really thinking abou just selling the eibach's and getting some Megan coilovers. Anyone else have any ideas?
Originally Posted by crono,Feb 17 2006, 09:15 PM
What exactly is the correct way to preload the suspension?
Originally Posted by RedUn,Mar 7 2006, 02:21 PM
wild guess but did u fasten the antiroll bar back up correctly??
(thats if they have to come off on the s2k I have no idea, not taken one apart......yet
)Thread
Moddiction
Apr 30, 2009 08:32 AM
