Electrical guru
Old Jun 21, 2011 | 06:48 PM
RogerHinga's Avatar
Default Electrical guru
I am having a hard time trying to figure out how to jump the connection on my passenger window. Basically I removed my soft top assembly. A friend's soft top control unit went bad so I sent him mine and didn't realize I needed it to roll up my passenger window. Is there a way to splice/jump the wires to be able to use my passenger window switch normally? The car is a 2000.
Thanks.
Old Jun 21, 2011 | 07:09 PM
EagleDon's Avatar
You should be able to locate a BLU/RED wire (+ UP) and a BLU/WHT wire (DOWN) for the passenger window. The BLU/RED needs power to activate the Passenger window for UP.
This should help.
Taken from Helms Manual: Window circuit diagram
Old Jun 21, 2011 | 07:15 PM
RogerHinga's Avatar
Its not just a simple splice of matching color the connector going to the window is blu/red and blu/wht.. but the connector going to the body doesn't have those color.. I can wire jump wires to roll it up and roll it down, but I want to be able to do it on the switch. If i jump the red/blu (b3) window connector side to blu/blk (a14) body connector side and red (b4) window connector and blk (b10) the windows will move up.
I think my problem is not completing the circuit.. i tried running power to both up and down like what you said but don't know which other wires to run to to ground to complete the circuit
I just want to be able to wire it and use my switch like normal.
Old Jun 22, 2011 | 02:47 AM
EagleDon's Avatar
Quote: Is there a way to splice/jump the wires to be able to use my passenger window switch normally? The car is a 2000.
There are three wires leading to the Top Control Unit. the BLU/RED, (UP), BLU/WHT (DN) and a RED/BLU which looks like the Master DN switch wire for the Top Control (when the Top is activated). The PWR lead running to the Main Switch is the RED/WHT wire.This wire when joined with the (UP or DN) wire activates the window. Also Black is the ground.
Let me know what success you have....
Old Jun 22, 2011 | 01:12 PM
Stratocaster's Avatar
Want yo buy the part you are missing instead of cutting up the wire harnesses? Make me an offer, I have a few of these in a box.
NAs2kCR
Aug 14, 2022 11:48 PM
dylanrush
Nov 12, 2013 12:13 PM
s2k harry
13
Aug 27, 2009 07:18 AM
nazaracing
Dec 27, 2007 08:30 PM
tetsuo73
May 10, 2005 12:38 PM
