Electrical Issues - Solved
Old Mar 12, 2012 | 08:07 AM
HKUSP40C's Avatar
Default Electrical Issues - Solved
For the past few months, I've been having issues with the Radio turning off and back on, and gauge cluster flickering. I did some research and some on this forum said to change the 2 accessory power relays by the steering column.
Well after spending about $40 on 2 new relays from Honda, problem still existed.
Something I should have done (and usually do) is ask one of my good friends if he had the same problem in his AP1. He said yes, and to clean out the ground terminal on the firewall by the battery. I removed the 10mm bolt on the firewall, cleaned the terminal and the firewall,and the problem is solved.
Just wanted to share this and save anyone else the headache that I went through.
Old Mar 12, 2012 | 08:51 AM
zestmyu's Avatar
Thanks for the info. I just started having similar problems. I'll give your solution a try this weekend to see how it goes.
Sent from my SAMSUNG-SGH-I727 using Tapatalk
MarkM735
Aug 11, 2013 06:19 PM
hondafied
Feb 28, 2010 07:52 AM
M2K
Aug 26, 2009 06:10 AM
Stookystar
Oct 28, 2008 02:11 PM
kOOpA
Feb 15, 2008 05:24 PM
