emanage ignition help
Old Sep 10, 2004 | 08:11 PM
home13oy75's Avatar
Default emanage ignition help
I just tried wiring up the ignition harness today and for some reason - cyc 4 wasn't firing or misfiring - the plug was wet. I checked the jumpers and dial and firing order is correct. I believe it is 1-3-4-2 off the top of my head. ANyways, my car runs great w/no cels prior to this on a comptech s/c.
I went and rewired igniton wires back to stock and unplugged the emanage ignition harness - car ran fine. So I know it is not a faulty coil pack or fouled spark plug. My question is that I started up the car after installing the ignition harness without powering up my laptop for the support tool. I believe ignition option is UNCHECKED. Could this have been the problem?
I read in the manual that if ppl have problems with starting the car JP2 should be set to 2-3 instead of 1-2. Although everyone here is running JP2 as 1-2.
I'm planning on trying to wire it back up again in a few days but I just want to make sure I am not overlooking anything - I thought that if ignition option was unchecked it would just ignore the emanage in terms of the ignition control aspect.
Sorry for the lengthy post.
Ray
Old Sep 10, 2004 | 08:41 PM
Slows2k's Avatar
Since your car is almost running normally, I can assume you have the coil's wired in the firing order.
CH1 -> Coil 1
CH2 -> Coil 3
CH3 -> Coil 4
CH4 -> Coil 2
I'd 1st double check your wiring connections on coil 4. From the brief time I was using the ignition harness, I don't believe the ignition option has to be checked for the ignition system to operate normally.
Old Sep 11, 2004 | 04:47 PM
home13oy75's Avatar
Is everyone setting JP1 - 1-2 and JP2 - 1-2?
I just want to make sure that I'm not overlooking the obvious.
Thanks!
Ray
Old Sep 12, 2004 | 01:56 PM
Slows2k's Avatar
Here's mine:
4-8-C Rotory switch settings
JP1 - 1-2 (Left two of three)
JP2 - 1-2 (Right two of three)
JP3 - 2-3 (Left two of three)
JP4 - 1-2 (Both two)
JP5 - Open (None)
JP6 - Open (None)
JP7 - Open (None)
Old Sep 15, 2004 | 08:53 PM
home13oy75's Avatar
Just a FYI for anyone wiring up the ignition portion for the Emanage. I have finally fixed the problem I was having earlier. It turns out that yellow/white which is suppose to be coil 4 IN - is actually coil 4 OUT. This is the only wire on the ignition harness that has a white stripe for OUT - all the other wires have black stripes.
It took me a long time to figure this out because cyclinder 4 wasn't firing - all wiring connections were checked. I wired it back to stock - starts up no problem. I just tooka gamble and reversed the wiring and it started p perfectly with no cel.
I hope this helps.
Ray
Old Sep 18, 2004 | 10:52 AM
Venomous S's Avatar
a little off topic here, does e-manage let you adjust idle speed?
Old Sep 18, 2004 | 12:41 PM
Slows2k's Avatar
No, It has no ability to adjust idle.
craftyvtec
Aug 29, 2008 06:46 PM
batikan
Apr 7, 2006 09:07 AM
Venomous S
Aug 24, 2005 11:38 PM
Partshelper
Feb 3, 2004 03:26 PM
