Endlinks and Shock body
Old Aug 9, 2017 | 01:26 AM
kpro22's Avatar
Default Endlinks and Shock body
Is this normal that the endlink is touching the shock body?
Old Aug 9, 2017 | 05:39 AM
hoobastnk90's Avatar
no that is not normal something weird going on here.
Old Aug 9, 2017 | 06:59 AM
Car Analogy's Avatar
Looks like could be endlink in backwards? Side with grease fitting should be on opposite side, away from shock?
Old Aug 9, 2017 | 07:00 AM
honda4eva89's Avatar
Yeah that's not normal...looks like the strut isn't sitting straight either
Old Aug 9, 2017 | 10:39 AM
kpro22's Avatar
Is it possible that the shock is backwards? The buddyclub N+ logo is facing towards the engine.
Old Aug 9, 2017 | 10:53 AM
Fokker's Avatar
Those aren't OEM endlinks. I think OEM should clear, but clearance issues aren't surprising given the size of those aftermarket ones.
Old Aug 10, 2017 | 07:24 AM
Chris_Lum's Avatar
also, it looks like the endlink might be bent from hitting the shock, so you might take a closer look and see if you need entirely new endlinks to begin with.
it looks like it could possibly be an aftermarket sway bar that shifted too far towards this side. If not aftermarket, then either the end links are too bulky and/or the bulky BC forks aren't helping clearance issues either. But there should be plenty of clearance between the shock body and end link so there's definitely a problem here.
Old Aug 11, 2017 | 05:36 AM
Slowcrash_101's Avatar
OEM endlinks don't have grease fittings.
Old Aug 11, 2017 | 01:33 PM
jyeung528's Avatar
not normal.
Old Aug 15, 2017 | 12:21 PM
gtracer's Avatar
My whiteline Endlinks with Whiteline Sway are very very close to my Tein coilovers... Not ideal but not something that I havent seen...
ans2k
Jul 12, 2012 09:54 PM
Wolfgang
32
Apr 12, 2007 06:49 PM
