Engine Bay Crossmember
Welp, my engine bay is getting sprayed again. Going to be relocating and shaving everything in there for this 2017 turbo setup. Question for the guys who have gone these routes, removing the crossmember all together (LS swap guys) or the guys who replaced the ugly oem crossmember with a tubular pipe. My question is, if the LS swap guys can run without one what's the point? Any noticable difference from removing it all together? I'm looking to replace the welded in piece with a removable one for an easier install and uninstall of the motor and trans together. But I'm gauging what diameter pipe to use? Any ideas? If you've replaced your crossmember with a removable one PLEASE POST PICTURES! :drive:
BUMP, I know someone has some custom shiz in here. Mine was cut out tonight to pull the motor and trans together :chainsaw:
I will be doing this very soon so will do a right up on it,I couldn't find a diy on this either....will be doing things a little different to what I've seen also, as to mounting points and how it's put togeather/welded.some people seem to cut the oem one out without taking note of how it was constructed. Can't see it being to difficult tho.
2 Attachment(s)
Hey OP.
ImportMuscle claims that removing the front cross member is OK for their swap because the motor mount plates are rigid-mounted to the frame rails. Therefore the motor becomes "one" with the chassis and acts as a stiffening component itself. The motor acts as a replacement for the OEM cross member. Take that for what you will. Most, if not all, of the turbo builds that I've seen on F-series engines that remove the OEM cross member end up replacing it with something custom made out of round or square tube. I'd say you DEFINITELY want to replace it if you remove it. While mine was out, we jacked up the front-left corner a bit and visibly watched it flex relative to the passenger side. My initial design was a copy-cat of baZurk's that he made for his turbo build. It used 2.5" square tube with 1/8" wall thickness, 4" square x 1/4" thick flanges welded onto each end, and 4" square x 1/2" thick mating flanges welded onto the frame rails. It used M10x1.5 flange bolts to attach the cross member to the frame rail flanges. The bar was welded at 45 deg. relative to the flanges. Picture of design below. Attachment 156736 I had to scrap this design due to interference with my coolant lines and a few other things. The final design was using a 1.5" x 3.0" rectangular tube with 1/8" wall thickness, 3-11/16" square flanges (same thicknesses as previous design), still using M10 bolts. We also ended up notching and welding the bar slightly in one spot for additional clearance to a radiator hose. The result was pretty dang hefty, at least as heavy as the OEM cross member that was removed. Attachment 156735 Surprisingly I don't have a picture of it mounted in place, and I didn't drive the car today else I'd go snap one now. I'll try to get one for you next time I drive it. |
Originally Posted by CoolGuy094
(Post 24150338)
My initial design...
Wondering how hard it would be for a layman to pick up something like SolidWorks! |
Originally Posted by HarryD
(Post 24150439)
Nice work man! Are you originally an engineer by trade?
Wondering how hard it would be for a layman to pick up something like SolidWorks! Solidworks is definitely one of the more user-friendly CAD systems that I've had the pleasure of working with. If you're proficient with computers (i.e. born in the 80's or later) then I think its certainly something you can pick up on your own. Especially with as many tutorials as you can find for free online in places like YouTube. So far I've worked with Solidworks, Pro Engineer (now Creo), Inventor, and a janky little software called Alibre Design (now Geomagic?). I can firmly say that Solidworks has been my favorite by far. I watch my friends program in Creo and I just sit there scratching my head, knowing there's much easier ways to do the same stuff in Solidworks. |
2 Attachment(s)
(Post 24150338)
Hey OP.
ImportMuscle claims that removing the front cross member is OK for their swap because the motor mount plates are rigid-mounted to the frame rails. Therefore the motor becomes "one" with the chassis and acts as a stiffening component itself. The motor acts as a replacement for the OEM cross member. Take that for what you will. Most, if not all, of the turbo builds that I've seen on F-series engines that remove the OEM cross member end up replacing it with something custom made out of round or square tube. I'd say you DEFINITELY want to replace it if you remove it. While mine was out, we jacked up the front-left corner a bit and visibly watched it flex relative to the passenger side. My initial design was a copy-cat of baZurk's that he made for his turbo build. It used 2.5" square tube with 1/8" wall thickness, 4" square x 1/4" thick flanges welded onto each end, and 4" square x 1/2" thick mating flanges welded onto the frame rails. It used M10x1.5 flange bolts to attach the cross member to the frame rail flanges. The bar was welded at 45 deg. relative to the flanges. Picture of design below. https://i.imgur.com/d0wnrKD.png I also like how Bobby Randolph made his and I'm looking at that route also. Attachment 76265 Attachment 76266 |
Originally Posted by KillerCom
(Post 24150837)
The nuts being recessed inside the welded on piece makes me a little weary.
We actually welded the thick flanges to the frame rails, then drilled and tapped the M10 holes all the way through the plates and the frame rails. So the bolt actually engages the frame rail as well just for a little extra thread length. I remember seeing Bobby's setup when he made it; very nice work indeed. |
Isn't the crossmember also an important part of the safety when it comes to forward collison?
I wouldn't just remove or change something like this when I have no clue about impactzones and stuff like that. |
3 Attachment(s)
(Post 24151001)
I'm not sure what you mean here... There aren't any nuts in my setup. The thicker plates that are welded to the frame rails have M10 tapped holes. That's what the M10 bolts thread into when you bolt on the cross member. The four bolt heads are easily accessible with a wrench, though a swivel socket makes them even easier to tighten/remove.
We actually welded the thick flanges to the frame rails, then drilled and tapped the M10 holes all the way through the plates and the frame rails. So the bolt actually engages the frame rail as well just for a little extra thread length. I remember seeing Bobby's setup when he made it; very nice work indeed. Attachment 76230 Attachment 76231 Attachment 76232 |
