Engine bogging below ~2500rpm
Old Dec 26, 2010 | 02:36 PM
Matt15's Avatar
Default Engine bogging below ~2500rpm
i did a search and the only threads i found on the topic were weather or A/C related.. so hopefully someone can help me out
here are the details:
-engine warmed up
-outside temp is 8 degrees C/ 46 degrees F
-bogs/bucks/misfires(?) when under load below 2500rpm
-A/C is off
-clutch is dying but not slipping noticably
-to avoid the bogging when starting from a stop, i have to let the clutch pedal up at 2700 rpm
-it also occurs if i decelerate from from a higher RPM. for example, i'm cruising at 5k, decelerate to 2k, then apply the gas again the car will start running like crap
any ideas?
thanks
Old Dec 26, 2010 | 06:11 PM
hytham's Avatar
no one ??
have the same broplem
Old Dec 26, 2010 | 06:43 PM
DocS2000's Avatar
Does the car idle well?
Old Dec 26, 2010 | 09:16 PM
Matt15's Avatar
yes.
but if i rev it then let the RPMs drop, they will dip low and the car will studder a bit then they bounce back to a normal idle
Old Dec 27, 2010 | 12:17 AM
woodburn's Avatar
Originally Posted by Matt15,Dec 26 2010, 10:16 PM
yes.
Its your map, check out the thread about the "map whack" it should help.
Old Dec 27, 2010 | 03:45 AM
INDYMAC's Avatar
Operating this car below 2500 RPM's is called "lugging" the engine. It is hard on the engine because it doesn't have enough torque/HP to perform the workload below 2500. Why are you trying to do this?
Old Dec 27, 2010 | 05:00 AM
Matt15's Avatar
already did... should i try swapping it with a new one?
Old Dec 27, 2010 | 05:07 AM
Matt15's Avatar
so you mean if i'm rolling on flat ground, the car cannot be operated at 2500 RPM? and the car is meant to nearly stall if i rev it in neutral and let the RPMs drop? i've had 2 S2Ks over the last year and a bit and this has only been a problem for a few weeks. there is definitely something wrong.
Old Dec 27, 2010 | 05:54 AM
INDYMAC's Avatar
If this is your complaint, then I say it is normal but very bad for the engine. In fact, I don't think anything could be harder on your engine short of being low on oil:
If you are maneuvering around in the taller gears (1st and 2nd), then you can get away with it sometimes.
Old Dec 27, 2010 | 07:29 AM
SpitfireS's Avatar
Sometimes, when bucking and bogging, you yourself (driver) get pushed forwards & backwards and you unwillingly press & let go of the throttle, making the car buck & bog even more.
Matt15 Posted on Dec 27 2010, 12:36 AM
Without a downshift that's to be expected.
That said: not that long ago someone posted that a new battery cured bogging & idle dipping, but that person also noticed the dash lights flicker during the bog /idle dip.
