Engine cut out randomly when approaching a stop
Old Sep 11, 2019 | 02:45 AM
windhund116's Avatar
What I'd do is run the car to burn off some of that gas you last used. Then, fill it with known good stuff. See if that solves the issue, before diving headlong into diagnosis and fixes. Bad gas has given me the Blues, before.
Good luck!
Old Sep 11, 2019 | 04:24 AM
RolanTHUNDER's Avatar
Good luck!
http://www.youtube.com/watch?v=Jif6NurekOg
Sensible. So should I run it down to the last bar of the fuel gauge before rushing off to a Shell station?
Thanks
Old Sep 12, 2019 | 07:34 AM
Well, at least down to 1/4 tank left. At least that's what I'd do.
Good luck! for cheap fix.
Old Sep 12, 2019 | 10:07 PM
Its close to a 1/4 now
I'll burn off a few more bars then go to Shell.
Old Sep 13, 2019 | 02:26 AM
starchland's Avatar
Was your ac on?
Old Sep 13, 2019 | 02:38 AM
Originally Posted by starchland
Was your ac on?
Nope. Used the fan on the highway though. Might have had it off by the time I approached the area where the cut outs occurred...
Come to think of it I hardly ever use my A/C...
Old Sep 13, 2019 | 02:39 AM
This is so funny though because at the traffic circle where the first cut out occurred I remember thinking "wow the idle is extremely smooth" only to look at the gauge cluster and realise the car's off
Old Sep 13, 2019 | 07:44 AM
engifineer's Avatar
If the car is running fine under acceleration and only does this dropping to idle I would not put my money on bad fuel being the cause. Not saying it is impossible, but usually if you are dealing with bad fuel, it will be worse under load than idle.
Old Sep 13, 2019 | 07:45 AM
engifineer's Avatar
Have you cleaned the Idle Air Control Valve? The can cause a rough/low idle or poor return to idle that could be what you are seeing here.
Old Sep 15, 2019 | 10:10 PM
I have cleaned it several months ago and spun the motor's opening with a screwdriver then applied a light amount of idle to the sides of the opening to lube it. After starting it up it idled quite high then came back down probably as a result of me having spun the motor. I'm wondering whether my IACV needs replacement or not...? I say that because I ran it down to 1 bar of fuel then filled up with Shell V Power but it still stalled twice at random locations.
