Engine Damage - Opinions on possible actions?
Hey, so my 2001 S2K suffered severe engine damage due to low oil. I'm a normal driver (ie. don't read up on S2Ks, don't push it hard, commuter vehicle, etc), and it wasn't until after I did some forum searching that I learned these things consume quart of oil/1k mi or more.
What really irks me is that I've always taken my car to a dealer for servicing and it was just in for a 90k service 3mths ago, and this happens now. Never was I informed I should be diligently checking and replacing oil in between service intervals.
Regardless, it looks like I have a few options:
1) Replace with a new/used engine
2) Overhaul engine and replace damaged parts
3) Sell the car for parts
Anybody have opinions on overhauling the engine and replacing whatever was damaged? Is this risky or an ok way to get the car back to working order?
Any info on how/where to sell the car for parts? The rest of the car is in very decent shape, so I can see some value in the parts. Anybody experienced in this and how much could one get for that?
Given that the car is 9 yrs old and worth maybe $10k (with a good engine), I'm not sure if it's worth repairing. I've been quoted $11k to install a new engine, which makes no sense since it's more than what the car is worth.
Input, experiences, or references to previous threads appreciated!
most shops should charge around 1000 to remove and replace the motor. a used engine with low miles can be had for around $2500.
To rebuild it you would e looking at around 2500-3000 + remove/reinstall engine.
where are you located?
Thanks for the quick feedback guys.
The $11k was for a brand new engine installed by a Honda dealer.
I'm in Bay Area, CA (where everything seems more expensive..) and I'm getting quoted $3500-4000 for a used engine with prob ~60k mi on it. Mechanic is telling me there's prob $1500-2000 on top for parts/labor to swap and I'd be at about $6k for new used engine assembly.
Hmm.. I think I'll investigate more costs for replacing the engine. I did a google search and found a few sites with engines. I'm assuming I could have that shipped to CA. Recs on particular places to look for parts?
As for mechanics, any Bay Area ppl have recommendations on reputable place who could do the swap? Would be good to compare prices with what I've been quoted already.
www.car-part.com you can usually find one for a decent price with a warranty.
I want to say book time for r&r engine is around 12 hrs
should be around 1000bux labor at 80/hr
figure you'll want to replace the fluids and clutch while its apart. they should do that for ZERO extra labor cost. it has to be done anyway.
Replace the spark plugs as well. Nothing else should need to be replaced.
Originally Posted by Saki GT,Sep 2 2010, 12:45 PM
What kind of engine damage are you talking about here?
I had it towed to a shop and the mechanic there says based on the symptoms there's definitely damage to the engine, but he can't assess exactly what is wrong unless he takes it apart - which is a 2 day job.
Given the work involved just to take it apart, inspect, repair, and rebuild, I'm getting recommendations of a new engine altogether.
Should be able to have a low mileage used engine including install and all parts in there for less than 5 grand. used engine 2500-3000 at most and install 1000 ish. figure money for fluids and some other stuff here and there.
It's clearly stated in the Owner's manual to check fluids including oil weekly.
If you bought the car used and didn't get a manual and didn't purchase a replacement manual, American Honda provides free information online.
Again, clearly spelled out (note this is general, so no cracks about automatic tranny or power steering fluid...
):http://www.ahm-ownerlink.com/Maintenance/m..._prev_maint.asp
Honda Maintenance Checks
Keep your Honda running like new. Between scheduled Maintenance Schedule items, periodically check the following items:
Engine oil (orange loop dipstick)
Weekly or when you stop for gas. Add oil if the level is below the lower mark.
Engine coolant
Weekly or when you stop for gas. Check the reserve tank; don't remove the radiator cap - the fluid is hot and may gush out.
Windshield washer fluid (blue cap)
Monthly. Frequent users should check each time they get gas.
Automatic transmission fluid (yellow loop dipstick)
Monthly
Brake fluid (large gray cap)
Monthly. Low brake fluid could indicate a problem. Take your Honda to a dealer for service immediately.
Clutch fluid (small gray cap, manual transmission only)
Monthly
Power steering fluid (red cap)
Monthly
Tires
Monthly. Check pressure. Check tread for uneven or excessive wear and foreign objects.
Battery
Monthly. Check condition (level of fluid or color of the indicator). Check terminals for corrosion.
Air conditioning
Weekly. Turn it on for a short time.
Lights
Monthly. Check them all -- head, tail, parking, and brake lights, high-mount brake light, turn signals, back up and license plate lights.
Engine coolant
Monthly
Monthly
Monthly
Tires
Battery
Air conditioning
Lights
