engine fully warm
Old Dec 2, 2014 | 06:32 PM
Slowcrash_101's Avatar
Sucks to live in Canada, it's like the exact opposite of Florida, over there it's cold, or a little less cold, here it's hot, and a little less hot
Old Dec 2, 2014 | 07:24 PM
HUNTERANGEL121's Avatar
We here in Miami have hot and dry, and hot and wet.
Old Dec 3, 2014 | 09:51 AM
Car Analogy's Avatar
Originally Posted by JFUSION
With an oil to coolant oil cooler it works in reverse in cold conditions, so it helps warm the oil using fully warmed coolant. Having 3 bars on the temp gauge would be close enough to fully warmed, the oil temp will lag a bit, but you are still in the safe territory for pushing the engine if you really needed. If you don't need to push the engine then wait a few minutes more after you get 3 bars. (This is for an ap1, not sure how many bars the ap2's have on their temp gauges)
The Audi that I used to approximate lag between coolant and oil reaching operating temp has an oil to coolant oil cooler, and it was still 4 min of hwy after coolant reached temp that oil began to creep above 150 on the gauge (lowest reading on gauge), which is still not warm enough to start pushing it. Not sure how well this equates to our cars, except that there surely is some lag, and its probably minutes, not seconds. So I think its prudent to wait and not just go by coolant temp.
Old Dec 3, 2014 | 09:53 AM
Originally Posted by Gotpepsi
When we got three bars! Keep it simple
I'd prefer rational over simple (and simple minded).
Old Dec 3, 2014 | 11:37 AM
Fokker's Avatar
Miami is like Houston, there is no dry. You have periods when it's not raining, but there's still enough humidity in the air that you get soaked anyway.
I usually wait 2-3 minutes after starting the car and then go.
Old Dec 4, 2014 | 08:26 AM
This is generally considered bad practice. Maybe on really old school cars this made some sense back in the day, but with modern fuel injection, best practice is to start engine and immediately start driving. You drive gently until things are warmed up. No lugging, no excess rev'ing. This is considered best for the engine, and has the added benefit of warming everything else at the same time (not to mention getting back 2-3 min of your life for every cold engine start - which I just did the math, if you start driving at 16 and stop when you reach 80, and average one such 2.5 min cold start/day, works out to, wait for it....40.5 days spent sitting in an idling car).
Old Dec 4, 2014 | 08:57 AM
Fokker's Avatar
150,000+ and it hasn't done anything negative to my car. I'm much more worried about the over 1/3 of my life I waste traveling to/from and working a job than I do about 1 month spent in a stationary car out of 768 months. All a matter of perspective.
Old Dec 4, 2014 | 10:45 AM
solitarycheese's Avatar
I'm with gotpepsi here. The AP1 already locks you below 6k RPM at 1 bar, 2 bars you can exceed 6k but no VTEC, and finally 3 bars let's you get on it. If it was necessary to wait all that time, I think Honda would have designed the car that way. Even if the oil is not fully up to temp, its still circulating and doing its job, no?
Old Dec 4, 2014 | 05:38 PM
But it's too thick so pressure is higher and can cause it's own problems.
Old Dec 4, 2014 | 08:23 PM
Respectfully, how would you know? What negative result would one expect from, say, driving hard on a cold engine. Premature engine wear. If your engine has more wear than it should, would there be any noticible symptoms? Not until it actually results in something like bearing knock.
So if warming up by idling excessively also caused more wear than otherwise, how would someone notice?
