engine fully warm
Old Dec 5, 2014 | 04:51 AM
  #21
Fokker's Avatar
Originally Posted by Car Analogy
Originally Posted by Fokker
150,000+ and it hasn't done anything negative to my car. I'm much more worried about the over 1/3 of my life I waste traveling to/from and working a job than I do about 1 month spent in a stationary car out of 768 months. All a matter of perspective.
Respectfully, how would you know? What negative result would one expect from, say, driving hard on a cold engine. Premature engine wear. If your engine has more wear than it should, would there be any noticible symptoms? Not until it actually results in something like bearing knock.
So if warming up by idling excessively also caused more wear than otherwise, how would someone notice?
I think I would have noticed something by now with that many miles if it was causing any excessive wear. You really can't compare the two without driving two cars identically for a large number of miles and then tearing apart the drivetrain to check wear levels. I haven't noticed any negative effects from doing so with driving 25,000 a year, autocross, track, canyon, and daily. You do it your way, I'll do it mine.
Old Dec 5, 2014 | 06:15 AM
  #22
fastflyer52's Avatar
Banned
That is a sad fact right there^ "I'm much more worried about the over 1/3 of my life I waste traveling to/from and working a job" but true. But what do you guys think when it is -3 degrees out side and the S is your only choice of transportation? Is it best for the motor to warm up all the way or maybe only 2 bars (AP1) so that way the diff and breaks all have time to warm up once you start driving?
Old Dec 6, 2014 | 10:10 PM
  #23
Car Analogy's Avatar
The consensus from experts is to warm a car by driving it. Gently. Lots of ingrained wifes tails about warming up idling pervade, and many are rooted to them (emotionally sometimes. Maybe it was Dad or Gramps that tought them this), and won't go away.
Old Dec 6, 2014 | 10:13 PM
  #24
Agreed. But the I'd notice if this was doing any damage, I don't get that. What is it one would expect to see, hear or feel if there was more wear than there should be (barring so much that you lose significant compression or get bearing knock)? You just wouldn't know.
Old Dec 6, 2014 | 10:24 PM
  #25
GSteg's Avatar
I'd be more worried about wasting gas during those extra 2 minutes than engine wear.
Old Dec 7, 2014 | 07:20 AM
  #26
Slowcrash_101's Avatar
The only thing I could think of engine wise, is that the pistons are smaller than they otherwise would be, and putting the load of the entire driveline, and weight of the car on them in very cold weather could cause the piston to ride the thrust surface in the cylinder a bit more harshly than it would if the piston had expanded to it's proper size. This is because the piston area isn't as evenly distributed in the cylinder, this might also place more stress on one side of the piston rings.
zakazak
Oct 5, 2013 05:12 AM
eraxpres
May 4, 2007 04:05 PM
mikecl713
Dec 2, 2003 10:40 PM
FormerH22a4
Jan 14, 2003 11:08 PM
Rick Hesel
Dec 29, 2001 05:59 PM
