Engine Issue
Old Oct 8, 2007 | 04:22 PM
xman03's Avatar
Default Engine Issue
I've started experiencing problems a few weeks ago... First thing I noted that the exhaust would have quite a smell to it whenever making a complete stop and others noted that the car would spit out clouds of smoke. Then I had a few instances of chatter upon start-up which I figured to be the cam-chain tensioner, however, my case was mild and only experienced a few times I believe. Now for some reason the car runs fine up until about 5k rpm where as after just starts to break up like it is almost hitting the rev limiter however it seems to get some fuel and struggles violently toward higher rpm. I'm not sure what the problem is and would appreciate any help. Thanks.
Old Oct 8, 2007 | 05:03 PM
rocrfella's Avatar
Check the spark plugs.
Old Oct 8, 2007 | 05:15 PM
NVMY4N's Avatar
Check
Vtec Solenoid
MAP sensor
and the Cat. <- could be clogged (hence the smell)
Old Oct 8, 2007 | 05:29 PM
REVZ TO9's Avatar
Banned
my vote is bad cat
Old Oct 8, 2007 | 10:23 PM
irphil's Avatar
Could be clogged fuel filter.
Old Oct 9, 2007 | 05:22 AM
xman03's Avatar
Failed to mention that I have an invidia testpipe so the cat is out of the question.
Old Oct 9, 2007 | 06:43 AM
MikeyCB's Avatar
Yeah faulty cat wouldn't result in plumes of smoke anyway, would it? I haven't noticed any visible difference in the exhaust without the cat on mine.
Old Oct 9, 2007 | 07:25 AM
MacGyver's Avatar
What color is the smoke, white or black? Color will tell us if it's coolant or oil getting in there...
Old Oct 9, 2007 | 10:14 AM
jyeung528's Avatar
no CEL's?
maybe its your injectors...or you've got bent valves...
do a compression and leakdown test...that should give you some answers...
Old Oct 9, 2007 | 02:22 PM
xman03's Avatar
Thanks for the help, is there any way the cam-chain tensioner could be the cause of the problems? I doubt it's bent valves as the engine runs fine as usual up to a certain rpm. Thanks.
