Engine light, code P0104
Old 01-22-2013, 03:28 PM
burglrdrift's Avatar
Default Engine light, code P0104
Hey S2ki,
So my AP2 2006 is throwing code P0104 which states " Mass or Volume Air Flow Circuit Intermittent". I have tried looking up what could be causing this but all im seeing is to replace the sensor, but our car doesnt have a MAF and was also informed our car does not have a EGR which is sometimes related to this issue.
Could it be related to my MAP sensor somehow even though that would be a different code?
my car currently has a Injen CAI if that will help diagnose the issue.
Thank you!
Bryan
Old 01-22-2013, 04:00 PM
xviper's Avatar
How'd you pull that code? It's not a common S2000 code.
Old 01-22-2013, 04:45 PM
i used a generic OBDII reader
Old 01-22-2013, 05:53 PM
xviper's Avatar
I don't think you can use one of those. It may give a false code. You need an OBD II CAN protocol scanner for that year.
Old 01-22-2013, 05:55 PM
so your saying its trying to look for something that doesnt exist so its throwing a code?
Old 01-22-2013, 06:03 PM
xviper's Avatar
No, it's already thrown the code. So the code exists. Your scanner may not have the ability to interpret the information. Later cars used OBD II with the CAN protocol. You need a scanner that will read it.
Or are you saying you didn't have a CEL but you just hooked up the scanner to see what it says? In that case, if the CEL is not on, why try to read for a code?
Old 01-22-2013, 06:10 PM
My engine light is on, its on due to the fact the i have a test pipe, every few weeks i check it to make sure there arent any other issue.. the only code existing at the moment besides my test pipe (02 sensor) is the P0104 which i obtained by using an OBDII scannner
Old 01-22-2013, 06:34 PM
Billman250's Avatar
Received 1,320 Likes on 800 Posts
What the guys are saying is your scanner may be what I call "off protocol", meaning it is interpreting the data wrong and giving a code it should not. I can check in the morning when I get to the shop.
Old 01-22-2013, 06:36 PM
alright thanks billman!
Old 01-22-2013, 06:40 PM
Billman250's Avatar
Post the brand and model of your code reader
Quick Reply: Engine light, code P0104
