Engine Mounting Stiffener Replacement
Old Aug 21, 2020 | 12:30 PM
rudyy's Avatar
Default Engine Mounting Stiffener Replacement
I want to replace the engine mounting stiffener (part # 50250-S2A-G00). Unfortunately, I do not have a car jack. Am I still able to replace using a long wrench as I am sure I am able to reach those 4 bolts holding it?
Old Aug 21, 2020 | 01:43 PM
Car Analogy's Avatar
I don't think you'll be able to reach that far back under such a low car. Even if a long wrench reaches them to remove, how will you get the bolts started when the replacement part is in place?
You will need to hold the stiffener in place as you get the bolts started. I can't see that being possible of car is flat on the ground.
If you put the money you'd have to pay someone to do this job towards buying a jack, then you'd have a jack.
Old Aug 24, 2020 | 12:01 PM
engifineer's Avatar
And stands ... you want a jack AND decent jack stands.
CaptainMike
Florida For Sale
Aug 14, 2017 04:17 AM
WhrDLMI
Hard at Work
2008
Nov 28, 2016 07:09 AM
Josh08
Sep 15, 2016 05:19 PM
s2kohoh
Jun 27, 2016 01:12 PM
Calzonii
Feb 21, 2016 12:37 PM
