Engine Noise
Old Apr 7, 2017 | 06:22 PM
LLB's Avatar
LLB
Default Engine Noise
Hello,
I'm new to the S2KI forum and a first time S2000 owner. I bought my AP1 used with 68,000 miles right after the New Year. Since then I've done minor stuff - aftermarket Voxx racing wheels, Ohlin coil overs, upgraded sound system, new burgundy soft top.
I cannot identify what noise this is when sitting in the driver seat. It is very irritating and appears to only be heard when idling.
Any pointers or assistance would be appreciative so I can chase it down and fix what ever is causing the noise.
Thank you
LLB
File Type: mov
Old Apr 8, 2017 | 03:07 AM
Chuck S's Avatar
Were you in the garage when this was recorded? Just curious.
-- Chuck
Old Apr 8, 2017 | 05:10 AM
LLB's Avatar
LLB
No this was in the driveway with the windows closed. It's a chirping noise and seems to be resonating from the engine bay to the interior dash. If anyone has experienced this issue please enlighten me.
Old Apr 13, 2017 | 09:48 AM
Xeon's Avatar
Take your serpentine belt off and start the car leave it running for 20 secs listen if the sound went away
Old Apr 13, 2017 | 10:11 AM
s2000Junky's Avatar
Yep, maybe a bearing going out in one of the accessories. It happens. OP Remove belt to troubleshoot. If sound goes away you know its one of them.
Old Apr 13, 2017 | 01:36 PM
Slowcrash_101's Avatar
Does it make noise with clutch pressed in?
Old Apr 13, 2017 | 05:53 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Check the PCV hose, does the car have crank vents?
Crank vents will cause chirping at idle.
Peeves
Oct 17, 2015 08:46 AM
caspiancopp
Nov 28, 2014 06:35 PM
TopGear
Sep 16, 2011 04:34 PM
SOL1D
Feb 16, 2011 11:42 AM
az3ar
Apr 23, 2009 11:57 AM
