Engine noise
Old Aug 6, 2007 | 11:11 PM
B.Money's Avatar
Default Engine noise
Hey guys, well for some reason my cars making this weird noise. Its almost like somethings rubbing on one of the belts on the engine. Its not a constant rubbing rather like an unbalanced rub where its repetitive. I looked high and low to see if something was caught in there anywhere or anything like that. The radiator fans are not on or anything like that. Only moving parts that I can see are the belts and such. TIA guys
Edit: I will say that I had my valves adjusted not too long ago buy a reputable shop, But that was close to a thousand miles ago.
Old Aug 7, 2007 | 08:10 AM
B.Money's Avatar
Old Aug 7, 2007 | 02:06 PM
B.Money's Avatar
Old Aug 7, 2007 | 03:55 PM
B.Money's Avatar
I think it may be the alternator. It seems to be directly related to belt speed. Is there any way to clean out/lube up the alternator with silicon spray or something??? thanks guys.
Old Aug 7, 2007 | 04:31 PM
B.Money's Avatar
okay newest update is I took the hose and washed the belt and everything off real good cleaned the dirt outta the pullys and everything and the noise so far is gone.. if this isnt a fix ill try something else out.
Old Aug 8, 2007 | 02:37 PM
slalom44's Avatar
Top Answer: 1
When I've had belt squeaks in the past, I pressed a bar of soap against the belt. It would temporarily lubricate the belt. If the squeaking stopped, I knew that was the problem. If not, I knew to look elsewhere.
It's possible that your belt tensioner was sticking, and cleaning everything loosened it up. If it comes back again, you might want to check it out.
Old Aug 8, 2007 | 04:35 PM
B.Money's Avatar
awesome thanks for the advice
gambit-irl
Feb 2, 2014 08:26 AM
Spec_Ops2087
Jun 21, 2013 08:23 PM
Empedocles99
May 23, 2005 12:56 PM
baldy74
Jul 29, 2003 08:08 AM
