Engine noise?
Old Nov 17, 2010 | 04:53 PM
s2k809's Avatar
Default Engine noise?
Why do i get a flapping type sound not all the time usually after i had drove the car for a while..Idk if its a "piston flap" noise basicly the sound sounds like flapping like if im low on oil but im not. its a ap1 with 112k
Like i said it only happens random days not all the time
Old Nov 17, 2010 | 06:31 PM
s2k809's Avatar
Also noise goes away a soon I step on cluch and engage gear but just stepping on clutch will make noise go away
Old Nov 17, 2010 | 06:37 PM
RacerXI's Avatar
Is this flapping noise on decel only?
Old Nov 17, 2010 | 06:43 PM
s2k809's Avatar
Only when in neutral I can hear it clearly at direct stop haven't noticed if I trow neutral while in motion
Old Nov 17, 2010 | 07:09 PM
RacerXI's Avatar
When you mention engaging clutch makes it go away, I think throwout bearing. I've never heard one "flap" though. It usually is a bad bearing type noise. Can you pinpoint where the noise is coming from?
Old Nov 18, 2010 | 09:33 AM
gCHOW's Avatar
i think i got the same thing as the OP.
when at idling at a standstill and not in gear i hear a "flapping" type noise but when i engage the clutch (not in gear, just clutch pedal in) it goes away. i've only noticed this at idle because it pretty feint.
i'm fairly certain the noise is coming from the tranny.
i'm chalked it up to the throwout bearing but i'm not gonna do a tranny teardown just for that. am i stupid to just let it go?
Old Nov 18, 2010 | 03:08 PM
s2k809's Avatar
Thats exactly my same problem.
At how many miles are you
Old Nov 18, 2010 | 05:02 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'll tell you what the noise is when I see you in the AM. Remind me
Old Nov 18, 2010 | 05:04 PM
s2k809's Avatar
Cool
Old Nov 19, 2010 | 12:19 PM
s2k809's Avatar
After coming back from seeing billman he thinks is the tranny...We will see what it really is when i have a clutch replacement done.
But most likely it is the tranny since noise goes away as soon as clutch is touched.
mattmatt510
Apr 21, 2014 07:53 PM
skeithr
Oct 23, 2008 06:55 PM
hecurb
Apr 18, 2007 01:26 PM
chihyuan
Mar 28, 2006 02:33 PM
RJ_S2K
Jun 21, 2002 04:29 AM
