Engine noise NOT TCT?
Old Feb 12, 2013 | 12:06 AM
deanbayley's Avatar
Default Engine noise NOT TCT?
Hi Everyone
Im after some advice.
My engine makes this ticking (metal on metal card in spokes) type sound when on idle. More so on Cold mornings, but even when the engine is warm.
Taken it to Honda a few times now and he can hear the noise but cant tell what it is. He seems to think it isnt the TCT, because you can hear it only from the Cabin side and cant really hear it when in the engine bay area.
Anyone had this same problem?
The noise goes away for a few seconds when you rev the engine a little. but it comes back when the idle rests back down.
Old Feb 12, 2013 | 04:50 AM
EgoFreak's Avatar
Mine does this also, I beleive its just time for a valve adjustment. Ive seen vidios of TCTs and mine doesnt sound like it.
Old Feb 12, 2013 | 04:58 AM
baZurk's Avatar
The injectors are also quite noisy. Mine tick pretty loudly sometimes.
Old Feb 12, 2013 | 05:03 AM
deanbayley's Avatar
My Valves should have been done on my last recent service. Cars only done 22k
Old Feb 12, 2013 | 07:20 AM
TrumpetTitan's Avatar
The owners manual says that a valve adjustment isn't needed until 105,000 miles. Unless you've had an overrev or done something else strange to the engine, I highly doubt it would be the valves.
Old Feb 12, 2013 | 11:09 AM
CrAzYNeSs's Avatar
Member
valve adjustment isn't recommended till 105K miles BUT Billman has found tight valves before the recommended specified valve adj. time frame. I forgot the reasoning behind it and maybe he or something else can chime in, but it is a good idea to get it done after a xx-thousand miles.
Old Feb 12, 2013 | 11:23 AM
realblag's Avatar
Possibly a slight exhaust leak at the manifold. Does it still have the OEM header on it?
Old Feb 12, 2013 | 12:19 PM
deanbayley's Avatar
It's all stock and I picked it up last May with 10k on the clock. Apparently the valves should get adjusted at 10-15k.
If it were the valves, would it not make the sound all the time?
The header is stock too
Old Feb 12, 2013 | 09:55 PM
EgoFreak's Avatar
My skyline made the exact same noise and i was told it just needed a valve adjustment. It cant hurt to get it done so im going to get it done and ill let ya know. I dont have the tools to do it myself so ill just have it done at one of the local shops.
mambo
May 1, 2023 04:19 PM
nikkei325i
Dec 15, 2010 09:48 PM
BlueSTwoK
Feb 24, 2005 04:16 PM
WRS2K
21
May 25, 2004 10:00 PM
