Engine not getting fuel?
Old Dec 13, 2021 | 10:13 AM
s2khate's Avatar
Default Engine not getting fuel?
How it’s going guys i recently purchased an ap1 with a recent engine swap not running, after diagnosing further the engine is getting spark, air, and fuel but i believe the fuel isn’t being shot through the injectors. Started the car up with starter fluid but died almost right away. Also the car has 210 compression all around and cranks healthy. Any ideas?
Old Dec 13, 2021 | 12:57 PM
noodels's Avatar
Maybe cam sensors wrongly plugged in,try swapping round
Old Dec 13, 2021 | 01:07 PM
s2khate's Avatar
Replaced it with a working one as well as test it for power and still the same. Also figured out fuse #21 isn’t getting any power under the dash.
Old Dec 13, 2021 | 01:26 PM
flanders's Avatar
Fuse #21 is ecu and main relay, you need to follow up on this.
It will not start if you don't get power here.
Old Dec 13, 2021 | 01:34 PM
s2khate's Avatar
any clue on what could cause it to not get any power?
Old Dec 13, 2021 | 01:46 PM
flanders's Avatar
Check the bigger fuses under the hood next to the battery.
You can find circuit diagrams and pretty much everything else to download from here https://s2000.club/
Old Dec 13, 2021 | 03:55 PM
s2khate's Avatar
thanks i’ll check back later to update.
Old Dec 14, 2021 | 06:58 PM
s2khate's Avatar
update: went through all of the major delays and fuses swapped and tested them no change fuse 21 is still not getting power.
Old Dec 15, 2021 | 04:00 AM
Car Analogy's Avatar
It started with starting fluid, right? Did I understand that correctly?
That woukd seem to rule out a spark issue, as well as spark timing issue. That would mean it rules out cam sensor, rules out power to ecu issue.
And you said its 'getting fuel', 'but maybe injectors aren't spraying'? Assuming that means you confirmed its generating fuel pressure, why not confirm injectors are spraying?
Remove injectors, plug them in one at a time, pointed into an old water bottle, and see if they spray, check pattern, etc. Check each one plugged into its connector (so you're checking power getting to connector too).
Old Dec 15, 2021 | 12:26 PM
s2khate's Avatar
Correct, fuel gets to the rail and there’s power to the injector plugs but i still haven’t tested the injector spray.
Starts up with starter fluid although dies almost right away leading me to believe injectors aren’t spraying.
marshallg
Jun 21, 2021 05:16 PM
armthehomeless
Nov 7, 2008 05:48 AM
Nishant
Aug 15, 2005 04:20 PM
pellisS2k
Dec 14, 2003 12:02 AM
NYC
May 22, 2003 12:47 PM
