Engine Options
If there aren’t any more new f20/22’s out there, what is an option for the s2k? And are there any that are as high revving? I know about the LS swaps but if you were going to use a Honda or Acura engine.
Are there any shops that can reliably rebuild the f20/22? When I sold mine, there wasn’t anyone that I knew about and it seemed like crate engines were running low.
Thanks
Thanks
K is the way. Buddy of mine is making the swap even though he has a perfectly good running F22 in his car right now. I feel like if you're boosted and you really like to run your car hard/track it/chase big power on stock internals, K is the way to go. Given how difficult it is to source a used F motor at a decent price, as well as how spotty they are in terms of reliability if you choose to rebuild them, it only makes logical sense to go K-swap if anything happens, or in my buddy's case, to just be ahead of it. K series has a much larger and healthier aftermarket, and given that they're an evolution of the F series, there's things that have been improved as well.
If mine goes this will be my route. ASM is pretty well known around us
https://www.shopasmotorsports.com/k-...ngine-packages
Do K engines rev as high? That’s one thing I loved about the f20/22. I know they can literally rev that high but I mean are they rated for three same range?
A K20A from a type R should do 9K with only a few small mods.
Similarly for a K20Z from a USDM Si/RSX
People do rev the K24 that high...but it likely won't last.
