Engine Rattle! What could it be ? , video inside
Old Jan 30, 2011 | 01:50 PM
DC4_2_AP1's Avatar
Default Engine Rattle! What could it be ? , video inside
I purchased an 03 S2000 in August with 64k miles. Completely stock. It has been running flawlessly since I've purchased it.
However, recently (over the past few days) I have noticed a rattle in low RPMs, it could also be at high RPMs but it is suttle and gets drawn out with the overall engine noise.
It is not affecting the engine performance, but I am noticing VTEC issues (going to whack the map sensor and give that a shot, separate issue I presume)
Here is the video:
[media]http://www.youtube.com/watch?v=3x2TVcA6DZE [/media]
What could it be ? Any ideas? I am going to do an oil change tomorrow, anything I should look for while I am at it ?
Old Jan 30, 2011 | 02:01 PM
INDYMAC's Avatar
I suspect that it is a timing chain auto tensioner (TCT).
What are your VTEC problems?
Old Jan 30, 2011 | 02:12 PM
DC4_2_AP1's Avatar
It seems to be inconsistent VTEC engagement, notice it especially in 1st, but other gears too. Sometimes engages normally around 6k, other times 8k, or sometimes never.
Old Jan 30, 2011 | 02:45 PM
DC4_2_AP1's Avatar
after doing some more research about the TCT, I'm 99% sure that is what is causing the sound.
Thanks a lot for pointing me in the right direction.
Old Jan 30, 2011 | 03:41 PM
aresk3b's Avatar
Vtec crossover will happen only if all the sensors that belong to that system are working correctly. (i.e. oil pressure sensor, speedo sensor etc.)
If one of them is failing, you will experiment vtec issues.
Old Jan 30, 2011 | 05:00 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Intermittent vtec issues is usually map sensor. Gentle map whack will likely fix it.
Old Jan 30, 2011 | 05:47 PM
zeroptzero's Avatar
make sure your oil levels are within the recommended range, and keep in mind the error on the dipstick readings (use the lower of the two readings).
Old Jan 31, 2011 | 05:13 AM
Billman250's Avatar
Top Answer: 1
I do think I clearly hear the TCT noise there also.
Old Jan 31, 2011 | 09:13 AM
ZeroF's Avatar
Sounds like TCT to me.
Have the worm gear sand blasted
alexford
Sep 6, 2012 08:06 AM
simonprelude
Oct 23, 2006 07:09 AM
Spec_Ops2087
Jun 15, 2006 10:34 AM
J33LUS
May 9, 2006 12:39 AM
