Engine Rebuild/Replacement?
Old Feb 26, 2024 | 08:02 AM
Slowcrash_101's Avatar
If you're going to 'rebuild' the head, you'll likely be replacing guides seats and a few valves. Probably exhaust on cylinder 1, and 2 & 3 are marginal while 4 is ok. If you're leaving the engine in the car, then just get the head work done. The guide work and valve job are not the easiest to do on this engine, any competent machine shop can do it, but you have to specify the correct angles on the valve job or it will cost you power. It's not a typical 60 45 30, the top cut is a 32 degree angle.
Burned valves on these engines are typical of a bad valve adjustment. You don't have to do it often but you do have to do it, and I would say inspect them every 40-50k miles, or ~4 years of driving.
Old Feb 26, 2024 | 11:38 AM
engifineer's Avatar
Originally Posted by CYANiDE91
I did my K swap last year (F20 -> K24). It will cost you double the cost of an F20 but you get a bit more power and a way more readily available motor. My car is now slowly being converted to mostly track duty so I felt it made sense to go K. Plenty of S2K guys with stock F20/22 doing plenty of track days without issues - so it's really a roll of the dice. I plan to own the car for a long time and I can't imagine the cost of F20/22 in 5+ years.
Yep the F series is pretty tough and is great on track, just sucks to replace one I have toyed with the idea of preemptively doing the kswap and selling my F20 to recoup some of the costs due to the price on them these days. But not sure I would do it. If I break the F20 then I will for sure look at the kswap route. Already even discussed some details with ASM on it so the thought is there!
theMBV
Apr 14, 2021 07:53 PM
Random1
Apr 11, 2017 09:12 PM
s2kbtos
Nov 8, 2015 11:06 PM
leoxle
Feb 23, 2014 05:57 PM
human
Jul 31, 2005 08:34 AM
