Engine rebuilding advices needed. Spun crank bearings
Old 01-05-2004 | 04:20 PM
  #21
honda9krpm's Avatar
The scratches are not very deep. However I like to repair the engine properly and to be able to handle a little bit more boost. It will be an expensive bill but I dont like any short cut and it's unfair for the next owner if I just rehone it.
Old 01-05-2004 | 06:32 PM
  #22
chris_barry's Avatar
Enlarging the bore 0.25mm to suit oversided pistons is standard engine reconditioning practice. It is much cheaper than sleeving, especially if you only have to do one cylinder ( make sure you balance all the pistons together).
You could actually get a set of +.25 sized low compression pistons so you can reduce the compression and recover the bores at the same time.
With forced induction I would suggest slightly more bore clearance to allow for more piston expansion as they will run hotter than designed.
Speedracer.
nomadicS2k
06-28-2009 04:04 PM
9kFever
09-03-2008 09:50 AM
RCR S2
07-13-2004 06:20 PM
Casas
04-27-2003 03:19 PM
Bombalahonda
02-13-2003 01:23 PM
Quick Reply: Engine rebuilding advices needed. Spun crank bearings
