engine removal from top without head attached?
Old Aug 12, 2009 | 09:35 AM
ChefJ's Avatar
Default engine removal from top without head attached?
I have the tranny and head removed. The engine hoist is in place but I am having trouble finding a spot solid enough to hook a cable to. Any suggestions on this. Thanks in advance.
Old Aug 12, 2009 | 02:38 PM
negcamber's Avatar
Drop it from under the car.
Old Aug 12, 2009 | 02:48 PM
SpitfireS's Avatar
With one of these:
Use 2 head bolts, screw them all the way in and lift it out.
Note: I was sure I was not going to use that engine so you might not want to do it that way - or get new head bolts just in case.
Allthough the block is not that heavy.
Old Aug 12, 2009 | 04:42 PM
pridyuk's Avatar
what i did and worked pretty good for me i took a strap and bolted one side with exhaust manifold mounting bolt by the engine mount. its a 14mm bolt and the other one i tied over the accessory bracket that holds alternator and ac compressor. or once i tied it around intake manifold, but since your head is out you dont have manifold in place. so accessory mount. or like the other guy said 2 head bolts and use leveler.
D1sclaimer
Dec 3, 2023 10:13 AM
AutoXJeff
May 4, 2017 02:16 PM
donaldmejr
Sep 30, 2014 05:38 AM
Nickamsweet
Sep 11, 2008 06:49 PM
Jason00S2000
Jun 29, 2004 08:46 PM
