Engine shuts down in 1st
Old Sep 27, 2006 | 12:25 PM
deaninkc's Avatar
Default Engine shuts down in 1st
I just purchased a used 2002 S2000 with 9K miles on it. They car is like new and runs great with one exception. Occasionally when punching the throttle in first gear and usually going around a corner the engine shuts down like it ran up against the rev limiter but more abruptly. It literally throws me forward until the seat belts catch me. The RPM's are no where close to the 9K rev limit. If I shift up to second it then runs fine. Is this a common problem or could there be a problem with a sensor or ECU. I can't seem to duplicate the problem intentionally, although I have not tried too hard.
Old Sep 27, 2006 | 01:09 PM
xviper's Avatar
You shouldn't beat on your car till it warms up. The ECU won't let you till you have 3 bars on the temp gauge.
Old Sep 27, 2006 | 03:13 PM
mikegarrison's Avatar
I nominate all instances of this same complaint as the prototypical "I am a dufus, please tell me so" post.
Old Sep 27, 2006 | 03:24 PM
xviper's Avatar
I second that emotion.
Old Sep 27, 2006 | 06:28 PM
RACER's Avatar
Main Entry: dufus
variant of DOOFUS
doofus
One entry found for doofus.
Main Entry: doo
Old Sep 27, 2006 | 06:29 PM
RACER's Avatar
Old Sep 28, 2006 | 07:06 AM
sweetj's Avatar
You guys are terrible
Old Oct 4, 2006 | 09:12 AM
deaninkc's Avatar
Geez, you guys are harsh. No that's not the problem. I had it happen the other day at a stop light after 15 min on the freeway. I've got 25 years as a SCCA road racer and mechanic, I know better than to flog a car when its cold.
Old Oct 4, 2006 | 09:17 AM
iDomN8U's Avatar
with 25 years as a SCCA racer, my question to you is..
when you WOT in 1st gear WHILE going around a corner, will that cause you car to go bye bye into a barrier?
Old Oct 4, 2006 | 10:22 AM
vtec9's Avatar
I guess it depends how sharp the corner is now doesn't it. also youre not going too fast when at low rpms in 1st. nowhere near 9k means youre not going too fast in 1st.
