Engine Start Button
Old Dec 19, 2006 | 06:06 PM
mytoesarecrazy's Avatar
Default Engine Start Button
Curious, as I have not done this yet. After the car is started, what happens if the
Engine Start button is pressed again while the engine is already running? Does it make the grinding noise? Just curious...
Old Dec 19, 2006 | 06:23 PM
RunUrAss's Avatar
i would assume so, yes...my advice to you...don't try..nothing good can come of it
-James-
Old Dec 19, 2006 | 06:27 PM
jimi's Avatar
Nothing will happen unless the clutch is depressed. However, I Read here on S2Ki that euro models will grind.
Old Dec 19, 2006 | 06:48 PM
jdmgpw04's Avatar
yes it will grind.... once you press the clutch....and press the engine start... yes it will grind....
Old Dec 19, 2006 | 07:51 PM
Enthralled's Avatar
why don't you try it out and let us know.
Old Dec 19, 2006 | 07:59 PM
Slows2k's Avatar
If the clutch is depressed the starter will turn.
Old Dec 19, 2006 | 09:08 PM
sexycheto88's Avatar
its just like any car when u turn it on.
all it does is start the starter lol.
so yeah it would.
Old Dec 19, 2006 | 09:11 PM
SkillmatiC's Avatar
ive actually tried it before...my car was sitting in neutral, and i was on the phone and i just pressed the button, nothing happened..
Old Dec 19, 2006 | 10:08 PM
mikegarrison's Avatar
Clutch interlock. If you press the clutch in, it will grind.
Old Dec 19, 2006 | 10:13 PM
s2k_dreams's Avatar
Now THIS is the dumbest thread ever!
