Engine Temp Results
Old Jun 17, 2002 | 12:44 PM
twohoos's Avatar
[QUOTE]Originally posted by gernby
[B]I have noticed that the car runs more consistant, whether it is hot outside or not.
Old Jun 17, 2002 | 12:52 PM
Gernby's Avatar
Former Sponsor
Don't you think that having lower temps would make the engine last longer? I know that the oil needs to be above 160 degrees or so, but I would think it would be best to keep it as close to that as possible, instead of the temps getting up to 215 degrees or more.
Old Jun 17, 2002 | 01:34 PM
cdelena's Avatar
Lower temperatures are usually associated with faster wear rates. The factory spec for minimum oil operating temperature is 176F, but those with oil temp guages report under hard running the oil will be over 220F with or without the cooling mods.
Old Jun 21, 2002 | 02:29 PM
CMiS2K's Avatar
very nice write up in my opinion
Old Jun 22, 2002 | 10:15 PM
Utah S2K's Avatar
Be careful with this data!!!
Which unit did you use ST20/30/40/60/80? Are you well versed in the meanings of the distance to spot size number and it's implications here? I'm all for science but thermal imaging is a little touchy.
Utah
P.S. The Raytech manufactur's thermometers as opposed to pyrometers (which cost a lot more and have a different distance to spot aspect ratio by definition).
Old Jun 23, 2002 | 05:51 AM
Gernby's Avatar
Former Sponsor
Utah
The Raytek MT4 has a 6:1 distance to spot size. That did make the measurements more difficult, but we just put it right up to it. That is why I think that the most accurate readings are the oil filter, head, and radiator hose. Those measurements were taken easily from 1/2" away.
S2000_FUN
Mar 16, 2011 12:34 PM
medicalstudent
Mar 1, 2005 07:51 PM
buckeye1
Jul 29, 2004 02:49 PM
peterwusc
Sep 19, 2002 02:06 PM
Gernby
Jun 6, 2002 01:33 PM
