Engine Temps
Hi everyone!
I have a 02' with 88k on the engine and 102k on the chassis and everything else. It's been about three months since I installed a AEM EMS version 2 series and upgraded to a 70mm throttle body with a 69mm port-matched intake manifold. I also have a Berk header-back single exhaust installed. So the car is currently tuned. My concern is am I running higher temperatures in the engine with these modifications compared to stock levels? If so, what cooling system modifications would decrease engine temps? I know an effective cooling system will prolong the car's longevity and reliability. I would really appreciate some recommendations on where to start and which parts you recommend.
BTW, old thermostat has been replaced with OEM part when I installed the intake manifold.
Also I plan to add headers and some cams in the next year or so.
I have been doing a lot of coolant system searching as of late. It appears to me that most aftermarket cooling upgrades over cool our cars when talking N/A. A good operating stock system should be quite easily sufficient. I was about to pull the trigger on buying an aftermarket rad, thermostat and fan switch till I searched. I did buy a PLX DM200 and my temp is almost always 183-184 even on the track. My fans don't even kick on unless I am sitting in traffic for awhile (203-204 degrees)
I can't actually tell you. Unfortunately, I did not tune my car myself. The fans do turn on quite often though while driving around the city. What I do notice is that the fans will stay on after I turn off the car until my AEM air/fuel ratio goes from ~14 to 18 and zeroes out.
Check your AEM EMS 2 to see if your tuner updated the temp calibration. Temp values from AEM runs higher.
https://www.s2ki.com/s2000/topic/184...-calibrations/
