Engine Temps
Check your AEM EMS 2 to see if your tuner updated the temp calibration. Temp values from AEM runs higher.
https://www.s2ki.com/s2000/topic/184...-calibrations/
Hook up a laptop to your aem and check the temps when the fans go on and off. Tell us when your fans are set to turn on. If the fans aren't set to turn on til 210 degrees, all your changes won't matter a whole lot.
Originally Posted by raikouS2K' timestamp='1372547947' post='22638411
I have been doing a lot of coolant system searching as of late. It appears to me that most aftermarket cooling upgrades over cool our cars when talking N/A. A good operating stock system should be quite easily sufficient. I was about to pull the trigger on buying an aftermarket rad, thermostat and fan switch till I searched. I did buy a PLX DM200 and my temp is almost always 183-184 even on the track. My fans don't even kick on unless I am sitting in traffic for awhile (203-204 degrees)
ON a side not has anyone with aem ems v2 have problems with their oem coolant gauge reading over half right when they start their car up and its cold? For some reason mine does and I have no idea why, after it runs for a minute or so it drops all the way down to the bottom like normal but it reads high when I first start it in the morning?
