Engine ticking at any RMP? Barely hear it on cold
Old Nov 13, 2023 | 08:14 PM
eleventhowner's Avatar
Default Engine ticking at any RMP? Barely hear it on cold
Hi everyone!
My 2006 S2000 recently developed issue, engine ticking/clicking at all rev range. So, title pretty much self-explanatory, as soon as engine dropping RMPs from cold start, I can hear the tick. I can barely notice it when cold. It gets quite after 10-20 min drive and sometimes tick "skipping". It rhythmical and constant. Billman said frequency is too low for timing chain. I recently put new TCT from Ballade (previous one was also Ballade, I had it for 4 years) and absolutely no change. I did valve adjustment (second one in last 12 months), no change. Tech said valve train is alright, in fact, two different shops said that. A few weeks ago replaced blown test-pipe gasket. No change, may be slightest bit. One thing, it became more quiet after awhile, the video is taken when it was the loudest. Car do not consume any oil, the only time I had low oil was after oil change at Honda dealershi(t)p. It was on L mark and again, both techs said it would not cause any issues. I topped it off to H mark. The problem started before that anyway. I took trip to LA (400 miles total) and I had issue ever since. Here are videos of ticking. No loss in power, if anything, after VA it has more power. Any help highly appreciated.
Old Nov 14, 2023 | 06:20 AM
windhund116's Avatar
I'm no expert on these things, but the noise doesn't sound too bad.
Do you still have the Ballade tensioner in your car? May want to think about getting a Billman unit.
Old Nov 14, 2023 | 11:54 AM
Im not sure if it's going to help. Like I said, I DM'ed Billman and he said it is not chain related. You can hear it on second video, when I put mic to the timing chain, it is pretty quiet, it is the loudest on the sides. I would expect at least a slightest change after new TCT, but there is none.
Could it be bent valve? I "overreved" car once by ~200 RMPs like 3 years ago (2nd gear ~48-49mph). Could tech check valves from top valve train cover?
And yeah, the noise not that bad, but it is super annoying and I don't want engine to blow up because of some minor problem. Tech clueless, asked 2.5K(!!!!) for diagnostics to remove timing chain cover. No, just not. Not because I don't want to spend money but because they not sure themselves what it is.
Old Nov 14, 2023 | 01:21 PM
Compression test will tell you if it's a bent valve.
Personally, I'd replace that Ballade tensioner with Billman's.
Old Nov 14, 2023 | 04:57 PM
That makes sense to do, had to start with it to be honest. I will do compression test this weekend and post results.
Old Nov 14, 2023 | 08:11 PM
Mr.Matchbox's Avatar
Ball Bearings in the Pulleys of the Serpentine Belt?
Old Nov 15, 2023 | 03:13 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
What header is in the car? Did you install the TCT yourself?
Old Nov 15, 2023 | 07:45 AM
bad_driver's Avatar
Given that this is relatively pain free to check--engine mounts? Had a ticking (albeit certainly not that loud, nor anywhere that rhythmical) that went away after replacing engine mounts. I'd also check the bolts that the rubber mount itself is mounted on.
Hope the compression test goes well.
Old Nov 15, 2023 | 08:05 AM
Car Analogy's Avatar
Get rid of ballade tensioner before it causes issues you don't already have. It can overtension chain, wreck havoc.
Old Nov 15, 2023 | 08:10 AM
Really easy to verify this. Just slip belt off pulley so its no longer tensioned, start engine see if noise gone.
Won't hurt anything run engine short time without belt. Just don't let it overheat. Belt doesn't have to be removed from bay. Ok to leave it in place untensioned. Easier to go back on.
