ENGINE TROUBLE
Old Mar 25, 2006 | 04:25 PM
LSRS2000's Avatar
Default ENGINE TROUBLE
WHATS UP GUYS, MY S HAS A PROBLEM. WHEN I PRESS MY GAS DOWN TO ACCELERATE THE REVS GO UP AS IF THE CLUTCH IS PRESSED DOWN, BUT ITS NOT, AND MY CAR GOES NO WHERE. IT DOES THIS THROUGH ALL THE GEARS. ANY HELP WOULD BE GGGGRRRREEEAAATTTT!
Old Mar 25, 2006 | 04:36 PM
jasonjm's Avatar
Your clutch is all but worn out? Just my guess.
Old Mar 25, 2006 | 04:49 PM
LSRS2000's Avatar
I WAS AFRAID OF THAT!
Old Mar 25, 2006 | 05:04 PM
stitos2k's Avatar
turn off the cap locks
Old Mar 25, 2006 | 05:05 PM
jasonjm's Avatar
It's a good thing. Now you can get a lightweight flywheel and a decent clutch.
Hope you don't kick the clutch delay when you drive hard...might want to change the driving habit or learn to drive without having it turn on.
Have fun!
Old Mar 25, 2006 | 05:21 PM
xviper's Avatar
[QUOTE=jasonjm,Mar 25 2006, 07:05 PM] It's a good thing.
Old Mar 25, 2006 | 05:30 PM
LSRS2000's Avatar
Thanks for the comments, Its a 2000 and with 60,000 miles
Old Mar 25, 2006 | 05:38 PM
xviper's Avatar
You do not have a clutch delay valve, so ignore that post.
Since you have a year 2000 with 60K miles, do you know if the clutch has ever been replaced? If it has not, I would surmize that your clutch is toast. In fact, if it is the original clutch, it is entirely possible that the clutch disc has worn itself down to the rivets. These rivets may have gouged into the flywheel already. You may be looking at a new flywheel also. I would suggest you get a lightweight one if you can spare the money. Along with that get the ACT clutch disc (re-worked OEM) and the Heavy Duty ACT Pressure Plate. You are looking at some big dollars to get this done.
Old Mar 25, 2006 | 07:39 PM
LSRS2000's Avatar
I'm afraid it is the original one. money for a clutch is not a problem, i was thinking about an exedy. how much is one? does it come with a flywheel, like a pkg deal? can i get a stronger clutch with a bone stock s?
Old Mar 25, 2006 | 07:51 PM
hondamanwill's Avatar
I don't get it. You just got into the car and BAM! it just stop working? Any more info on maybe how it was before?
