Engine VIN
Old Oct 3, 2015 | 12:32 PM
plizzat's Avatar
Default Engine VIN
Hello everyone,
I was wondering if there was a way to match the engine with the car? Is there a VIN that will uniquely identify it? Thanks.
Old Oct 3, 2015 | 12:43 PM
dagle's Avatar
Yeah the VIN.
Old Oct 3, 2015 | 01:37 PM
sgvsuperdude's Avatar
https://www.s2ki.com/s2000/topic/883...ion-on-engine/
This should help what you are looking for....
Old Oct 3, 2015 | 04:51 PM
plizzat's Avatar
Thank's that's helpful, looks like its behind the engine by the firewall. I wonder if that's the only location.
Old Oct 6, 2015 | 10:37 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
That is the only location as far as engine vin.
The vin plate is actually attached to the cylinder head, not the engine block.
Old Oct 6, 2015 | 02:29 PM
plizzat's Avatar
Thanks. Do you know if theres an easy way to look at it?
Old Oct 7, 2015 | 04:10 AM
slalom44's Avatar
Top Answer: 1
It's easily visible when you lower the engine while doing a clutch job. Otherwise, it's impossible to see in a running car.
Old Oct 7, 2015 | 07:22 AM
MM3Kwolik's Avatar
Not true. An inspection mirror and a flashlight can allow you to match the last 4 digits easily.
Old Oct 7, 2015 | 02:12 PM
shind3's Avatar
Is there enough room to put a camera phone back there and take a picture?
Old Oct 7, 2015 | 03:25 PM
windhund116's Avatar
Bet yes, with a selfie extension rod.
http://www.amazon.com/gp/product/B00...=sr_1_7&sr=8-7
