EPS
Old Jul 2, 2009 | 05:57 PM
Slows2k's Avatar
On a US spec car you can
Old Jul 2, 2009 | 06:04 PM
AusS2000's Avatar
If you are facing the EPS unit the input plug from the firewall goes in the right side and the output the left. As the unit is mounted on the right hand side of the car (from drivers perspective) in a RHD model the input socket is closer to the firewall so the input and output don't cross.
I expect on a LHD car it is the same module but mounted on the left. Hence the input socket is further forward that the output socket and the input and output plugs cross under the unit. This would lead to the sort of confusion you refer to with them being incorrectly connected.
Is this correct?
Old Jul 2, 2009 | 06:14 PM
Slows2k's Avatar
US Spec cars have the EPS control unit mounted to the outboard side of the battery, on the passengers or right side. The 2 plugs that can swap will reach either position.
You don't have any turbo heat nearby EPS parts do you?
Old Jul 2, 2009 | 06:40 PM
AusS2000's Avatar
The turbo sits right beside the EPS unit but there is an ABS unit and master cylinder in between. I did massively over heat the turbo once due to a retard (the timing, not me) and as a result replaced the ABS unit. I won't be surprised if this is the problem.
I have since shielded the turbo pretty heavily and got the crank position signal correct so it won't happen again.
Old Jul 2, 2009 | 06:44 PM
Slows2k's Avatar
If you can find a tester EPS unit it would be worth shot.. Doing all the input tests to the EPS unit many not tell you anything, sometimes replacing with a known good component is easiest.
Old Jul 2, 2009 | 06:47 PM
AusS2000's Avatar
Yeah, I think I'll source one and try it. Can never have too many spares.
Old Jul 2, 2009 | 06:59 PM
Slows2k's Avatar
You gotta have a local willing to lend a part for the cause
Old Jul 2, 2009 | 07:07 PM
AusS2000's Avatar
You'd think so wouldn't ya.
Old Jul 4, 2009 | 03:46 AM
Slows2k's Avatar
The 2 outboard 2 pin connectors are the ones can can be plugged in to the wrong sockets.
Old Jul 14, 2009 | 09:51 PM
AusS2000's Avatar
Well I have a confession to make.
Seems my power steering was working all along.
I pulled my EPS box and tried to turn the wheel and absolutely no go. I guess the 235s I'm running at the front are making it feel like I have no power assistance when I actually have, just not enough.
