EPS, Rack & Pinion?
Old Jul 12, 2005 | 09:11 AM
gti2000's Avatar
Default EPS, Rack & Pinion?
I've had my EPS light coming off and on randomly, finally took the airbox out, cleaned the EPS torque sensor, reset the EPS (unplugged the battery), and the EPS light is on constantly now.
Could it be possible the rack & pinion needs to be replaced? Can I replace just the sensor? I am out of guesses but I'm afraid to take it to a dealer whom seem to know nothing about the EPS system on the S2000.
If anyone can share some insight it would be greatly appreciated.
Old Jul 12, 2005 | 01:00 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The EPS has it's own trouble codes, just like the engine.
A scan will reveal the codes. Being much simpler that the engine, the code will tell most of the story about what you need to do.
Old Jul 12, 2005 | 03:02 PM
Slows2k's Avatar
You gotta have the EPS code before replacing parts. It will be very expensive to shotgun repair.
Old Jul 12, 2005 | 03:37 PM
fperra's Avatar
My EPS has been on ever since I installed my last turbo setup I had to unbolt the steering rack to run the charge pipe between it and the frame cross member. It goes out as soon as I start driving and the steering is fine. Just a matter of getting it reset I suppose. I'll get around to that someday.
Old Jul 12, 2005 | 03:56 PM
Slows2k's Avatar
There are 2 connectors on the bottom of the EPS controller. They can be installed backwards. Connector "A" goes to the furthest forward 2 pin connector. "A" has GRN/RED wires.
Connector "C" goes in the rearward position. "C" has BLK and WHT/RD.
The EPS will not work with these 2 connectors reversed. You will need to clear the trouble codes after correcting the connector placement.
Earlysport
Jan 18, 2017 03:07 PM
AJVH2000
Jun 18, 2015 01:47 PM
Bigchief
Mar 12, 2015 05:22 AM
Ridla
Jul 10, 2012 12:23 AM
harrison1990
Jan 13, 2011 10:50 AM
