EPS Problem
Old Mar 11, 2015 | 05:00 AM
Bigchief's Avatar
Default EPS Problem
Hello,
my EPS seems to have gradually given up over time. Initially the EPS light would appear intermittently and would go off if i started the car with the steering in full locked.
the EPS light is now on permenantly and I have no power steering. I have tried disconnecting and reconnecting the connectors and giving the gold unit a thud (as recommended incase the relay was stuck) and neither of these have worked.
What should my next port of call be? should I replace the EPS unit? is there anything firther I can do/check before i start replacing parts?
Any help would be greatly appreciated.
Old Mar 11, 2015 | 01:35 PM
Dembo's Avatar
Tried the reset procedure? Doesn't sound like it'd work; you probably need to try replacing bits.
Old Mar 11, 2015 | 02:07 PM
Daytona-Dave's Avatar
Get it read by someone with a code reader, Snap-on, launch etc all read the various units in the S2000
Old Mar 12, 2015 | 05:22 AM
not4s4l3's Avatar
Try this(Torque sensor neutral position)
https://www.s2ki.com/s2000/topic/728...#entry17056347
or this Resetting the EPS
https://www.s2ki.com/s2000/topic/116...1#entry1556872
Best of luck!
speedzx
Feb 28, 2017 11:27 AM
nicholasbartleet
Mar 20, 2011 07:12 AM
defcon83
Nov 7, 2010 06:16 AM
ndk4
Oct 16, 2010 04:46 AM
sman
Dec 9, 2002 10:14 AM
