Error code with MY00 P0108
Old Jul 29, 2005 | 08:19 PM
Wisconsin S2k's Avatar
Originally Posted by Slows2k,Jul 29 2005, 06:56 PM
Unless the PCM is causing the DTC, it's not going to fix it. That will be an awfully expensive guess, for almost no performance gain. +the cost of reprogramming the keys.
agreed. there is no reason for you to buy an 03 ECU.
Old Jul 29, 2005 | 08:49 PM
xviper's Avatar
Originally Posted by hydeaway,Jul 29 2005, 05:07 PM
the comptech ESM is actually soddered (recommended by comptech and xviper) was done about 5 months ago.
Is it possible that one of the critical soldered connections has let go? I've seen this whole MAP code several times before and a good soldering job has resolved all the problems. You are the first one (of the 5 or so owners whom I've dealt with) I've heard of to report a recurrence of this situation after the connections have been soldered. One such owner that I personally know has been trouble free for over a year. He also got the MAP code and like you, after the dealer put in a new sensor, the same problem came back. After the soldering job, never again.
Old Jul 30, 2005 | 05:25 AM
hydeaway's Avatar
im going to check the soldered connection just in case -
Old Jul 30, 2005 | 08:16 AM
hydeaway's Avatar
the Red ECM wire looked like it didnt get soldered very well - fixed that, will monitor if the error comes back.
Old Jul 30, 2005 | 08:43 AM
xviper's Avatar
Reset the ECU so it can start all over again.
Old Jul 30, 2005 | 10:57 AM
hydeaway's Avatar
reset ECU - drove it for a bit and no error - hopefully that fixed it.
Old Jul 30, 2005 | 01:33 PM
xviper's Avatar
Good luck. However, you may not be out of the woods until you've driven it a while. MAP codes can sometimes take a few days before returning.
Old Jul 31, 2005 | 02:13 PM
hydeaway's Avatar
been driving it all weekend and so fat so good -- i think its fixed (cross my fingers) -- thanks xviper / slow / and Wis.... Appreciate the help....
unowned
Apr 11, 2021 08:19 AM
TRD_Celica
Mar 3, 2011 01:09 PM
Deliverance
Aug 4, 2010 07:17 PM
Putney
Jun 13, 2008 04:28 AM
jason4207
Sep 2, 2005 11:10 AM
