Excessive AP1 Oil Consumption
Hi, All! My MY'03 AP1 has been burning a nutty amount of oil, wondering if it's time for a rebuild or at the very least a ring-job.
It has just under 200k miles and I did an oil change on it at about half a tank of gas ago with Amsoil 5W-30. Well, I went to fill up today and checked the oil, it was well below the L so I figure I must be about 2Qts low (after checking it cold, it was only about half of a quart).
I did a compression test when I bought it (A little under a year ago) and got 200-180-180-185, so not stellar but passing considering the mileage.
I have the stuff to do the supra PCV mod, and valve stem seals which I plan to do soon, but I wonder how much (if any) difference they'll make. I VTEC just about every chance I get, as you can imagine.
So bottom line for me is if the PCV + valve seals don't fix it, is my only option to pull the engine and do the rings + hone cylinders? I know I've read if you just do the rings and don't hone the cylinders the rings won't seat well and the problem could be even worse.
Thanks for any advice in advance!
rpg51 (08-24-2020)
Yes, do a proper leak down test to see where you are losing compression.
You could have a ton of blowby going past your rings or you could have valves out of adjustment severely and need the valve seat machined.
I would start with the PCV just to get a decent base line. Then before you do the Valve Stem seals, do the leak down test. If you hear more air coming from your dipstick tube then it's most likely all in the rings.
There are some liquids that can "help" the rings get back into place but I have not seen good results but on a handful or Ford Modular V8s and a few 2011 Coyotes so your milage may vary.
I'm having my valve seals replaced when doing the intake valve retainers just for the peace of mind and the "while I'm in there" of it.
It has just under 200k miles and I did an oil change on it at about half a tank of gas ago with Amsoil 5W-30. Well, I went to fill up today and checked the oil, it was well below the L so I figure I must be about 2Qts low (I'm gonna re-check and top it up tomorrow) which seems really excessive to me.
Thanks!
Received 1,302 Likes
You're assuming the gas station parking lot is level.
And how much time did you allow for the oil to drip back into the pan.
Are you sure it was all the way full before?
If you were burning 1 or 2 qts in ~100 miles, your car would drive down the street looking like a smoke machine
You could fog for mosquitoes.
So you're probably not burning that much oil without some visible evidence, as well as the smell of burning oil.
I doubt you're really burning that much oil.
try your valve seals and PCV first. Hope you're using Honda seals and not aftermarket.
No, its not going to work to do a bottom end rebuild. If anything, it'll just be worse.
Buy a known good, factory built longblock from a part out.
sell yours to someone that wants to iron sleeve it.
rpg51 (08-25-2020)
I checked it while it was still warm, haven't been out to look since it's cooled but I'll update once I do.
I can smell oil but it's not fogging excessively.
I'm 100% sure it was full before, I added 5q exactly and double checked the dipstick after the change and it confirmed it was full.
It's not leaving a huge puddle of oil so I figure it has to be burning it, unless it's hiding it somewhere I don't know about.
I'm going to be putting in new OEM valve stem seals and PCV asap, I'll update once I do as well.
Has the oil usage gone up, a lot, over the last year? Or did the car always burn a certain amount. Then, just recently dropped 2 quarts?
Here is a very good post on oil use
https://www.s2ki.com/forums/s2000-un...ntoms-1188455/
Check all what he did and if you don't have a '04, '05 valve cover you might try that too with a TSX pcv.
Rod
Rod
Okay, so I checked it after it's cooled off and it was only down about 2 or 3 hash marks. Which, while a relief, also makes me feel a bit silly. If I did my math right that means I'm burning a quart every 500 miles, which is still kinda a lot, but not as bad as I thought it was. I'm still going to go ahead and do the pcv + leak down + valve seals and see if that helps at all.
In my experience its typical you get usage out of both the rings and the valve seals/guides both. Considering the alternative and how much oil you are burning which is a ton at 1q/500 miles, its probably worth doing the valve seals and hope that takes care of at least a good portion of it and hope the guides aren't too worn because that will require a head pull or more invested to do, which may not be worth it if you discover after seals that nothing has changed, meaning majority is rings. You don't have to pull then head to do the seals, so its one of the more lenient ways to deal with oil burning shy of engine rebuild (or replacement typically in the S2000 case).
