Exhaust Cutout Before Cat
I am about to order an electronic exhaust cutout and I am wondering if I should put in front or behind the cat. I'm thinking it might sound better in front of the cat, but at the same time I think there is a sensor there by the cat? Will this reak havoc of any kind if there is no exhaust getting to the cat? Will there be a CEL and will that CEL hurt my horsepower? I am doing the cutout for the sound alone, so lets not turn this into another thread about the benfits or lack thereof of backpressure.
I never get my questions answered when that happens.
You will have a CEL. Because you are bypassing the convertor.
Your car will be exceptionally loud as well. It may burn the exhaust valve seats due to not using an exhaust system, and you also may set fire to anything you drive over or the car itself.
Still sound like a good idea?
As far as burning exhaust valve seats because of no "exhaust system", how many race cars are burning exhaust seats? Your exhaust valve seats will be fine unless you start running very lean.
Slows2k is quite right about it being very loud though, although I never remember setting fire to anything with the car. Made the tires smoke plenty of times, even if they were the wrong ones.
Originally Posted by Cycloneranga,Oct 24 2006, 09:37 PM
So would it be alright behind the cat? Will you explain to me what exactly happens to make it burn the valve seats? I don't get that. Would the exhaust gases get pulled back that far some how?
Having an exhaust cutout will make you run a bit leaner, if nothing else is changed, but it should not move you more then half a point at most.
I havn't had my S2000 on a dyno yet to check it's AFR, but knowing factory tunes, it probably runs rich enough at WOT that it will help you to lean it out a hair.
If you are cruising around then the O2 sensor will take care of the AFR, but if you are crusing around with the cutout open you are doing everyone around you quite the disservice.
Originally Posted by Cycloneranga,Oct 25 2006, 08:15 PM
While I have a couple people's attention, one more thing: what is the little pipe that comes off at a perpendicular angle behind the cat, and then stops?
jwkim
Dec 4, 2003 04:22 PM
SAIYAJIN
Apr 4, 2003 10:27 AM
