Exhaust issues
Old Aug 20, 2016 | 04:49 AM
Tabblink's Avatar
Default Exhaust issues
Hi guys,
I have a MK1 escort fitted with an s2000 engine. I done the conversion myself and at the time just mated it to my standard 2" exhaust system. Just been for a rolling road to see if the exhaust is restricting things and it seems it is.
I only hit 195bhp at the fly.
Replacing the exhaust with a 2.5 or 2.75" exhaust is not a problem. However I have got some queries about the CEL and lambda sensors. What is the size of an OEM exhaust anyway? What size are the popular aftermarket ones?
I am running just the pre cat sensor on my car, as I didn't have another sensor to put into the exhaust. Will this cause an issue for the ECU to pull things back abit? Should I be running the post cat sensor too? If so do I run the CEL fix as spacer or not?
I cant read my ECU codes as I can't find a decent OBD2 pin out for an s2k to wire one into my car. So I'm stuck with an EML that I can't diagnose
Old Aug 20, 2016 | 06:13 AM
cdelena's Avatar
195 wheel HP is not unusual for an early AP1 drive train.
Old Aug 20, 2016 | 11:13 AM
Forziii's Avatar
195 sounds right..
stock exhaust is I believe 60mm into something less (dual tips)
most popular (for a gain) is 70mm
Old Aug 20, 2016 | 12:14 PM
Tabblink's Avatar
The dyno run was at the fly. I asked him for @wheels but he already had it set up for everyone's else's at the fly. It was a RR day thing.
I would be happy with 195bhp at the wheels.
Any info on the lambda sensors?
Old Aug 21, 2016 | 06:36 AM
Chuck S's Avatar
A healthy AP1 engine should easily show 195bhp at the wheels thru the Honda drive train. Wheel horsepower is all that can be measured without putting the engine on a stand so any "flywheel" reading taken off the wheel readings is a WAG with lots of assumptions.
AP1 header is a nominal 57mm and feeds nominal 60mm exhaust piping. Bigger exhaust piping is a constant discussion here. Just slapping on a 70mm system at the header seems to not achieve desired results due to exhaust pulsing, back pressure, and other things I don't understand. Torque suffers. And horsepower is merely a mathematical formula based on torque. Better results seem to happen with a smooth transition of exhaust diameters. There are some nice header sets available that will feed a 70+mm exhaust efficiently. Nice meaning expensive.
-- Chuck
PapiChuloNica
Aug 8, 2014 04:42 AM
tommy holly
Jun 7, 2014 09:21 AM
TheStoat
May 17, 2009 02:15 PM
XclusiveAutosports
Apr 4, 2007 07:03 AM
tenblade2001
Aug 26, 2003 06:33 PM
