Extreme Idle Drop
Old Sep 22, 2015 | 03:38 PM
FIRSTCAR-S2K's Avatar
Default Extreme Idle Drop
Hey guys, it's my first post on S2KI. I have an 01 AP1 that has around 70k miles on the engine. Lately it has been having extreme idle drop, like every time you put the clutch in it will drop to 500-600 RPMs if it doesn't stall. It is very annoying and embarrassing having your car stall 5-6 times a day. Having the A/C on makes a difference in amount of stalls, but even with it off it still stalls way too much.The idle seems pretty rough too. Again,it's not driver error stalling the car, revs drop too low and it stalls quietly. I clean the IAC almost every week, have a ziptie around the MAP and have cleared the throttle body. What else can I do? Thanks
Old Sep 23, 2015 | 11:36 AM
zSran's Avatar
I have the exact same problem. Cleaned. Iac and everything. In for responses
Old Sep 23, 2015 | 12:31 PM
clio's Avatar
Iac valve and map zip tie etc are what to go for straight away with these issues, but if you have covered these off it may be an o2 sensor.
Old Sep 23, 2015 | 01:52 PM
I was thinking about swapping the IAC and MAP from my other AP1 (which doesn't idle drop) to see what what happens. Could be O2 sensor. Thanks for replying
Old Sep 23, 2015 | 01:53 PM
Very annoying and embarrassing, lets hope someone gives a solution
Old Sep 25, 2015 | 01:14 PM
Hey guys, sorry for "bumping" this post. Anybody have anything that could help me?
Old Sep 25, 2015 | 02:16 PM
clio's Avatar
When you say you've cleaned the iacv have you removed the pentacle bits (to remove the electric motor) and then made sure the valve component spins freely?
Old Sep 29, 2015 | 10:40 AM
Raabjorn's Avatar
I remember reading about someone having a similar problem, but after adjusting the valves, the car was fine. Sometimes they are way of, and needs adjustment long before the service book says...
Old Sep 29, 2015 | 01:15 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Do not clean the IAC with any cleaner.
Take it apart and free up the rotary shaft if you want real results.
Old Sep 29, 2015 | 06:53 PM
Gotpepsi's Avatar
You need a special tool to take apart the IAC. It's a 5 point torx (T20) -or- you can cut the screws with a dremel.
