F20c engine Experts opinions needed
Old Mar 23, 2003 | 07:57 PM
Insomniak's Avatar
i finally got my engine rebuilt and got it back tonight.. drove it home tonight.. trying to keep the rpms under 3k for the first 300miles.. but i noticed driving home.. if i even get the rpms to 3k.. the engine starts to bog ..
anyone have any idea what might cause this.. 3 ideas i've had so far..
1. need new ignition coil packs
2. fuel starvation.. not sure why.. no fuel leaks..
3. battery power.. it sat for 2 months.. finally starting back up.. had to jump start it to drive it home.
new engine.. has freshly sleeved block.. new rings.. pistons.. about 10 miles on it right now.
Old Mar 23, 2003 | 09:10 PM
ultimate lurker's Avatar
Need more input....
Run a compression test, check for engine codes (probably none since you didn't mention it), see if you can't put a wideband on it and see what the mixture is doing.
UL
Old Mar 24, 2003 | 02:45 AM
Insomniak's Avatar
Thanks UL, it does have a check engine light on.. ever since it first started up last night.. taking it to honda today to find out what the codes are... engine runs fine at 2,500rpm and below.. idles right around 1k
Old Mar 24, 2003 | 06:33 AM
Elistan's Avatar
Ouch, what happened to your engine that required a rebuild?
In any case, the majority of problems I've heard of that include a normal idle and low rpm use, but with problems at higher revs has had something to do with the MAP sensor.
Old Mar 24, 2003 | 06:43 AM
Insomniak's Avatar
i'll ask them to check that as well.. found this thread.. looks like joes2k was having a similar problem.. anything over 2,500 on my car and it seems like it starts to miss fire really bad..
thread where joe had same issues fixed by fuel injectors, igniton coil packs and new plugs:
https://www.s2ki.com/forums/showthread.php?...?threadid=27547
Old Mar 24, 2003 | 12:06 PM
Insomniak's Avatar
ok found out the crank sensor went out.. hope that do any damage driving it for a few miles.
Old Mar 24, 2003 | 01:30 PM
Elistan's Avatar
Interesting. UL, would you mind giving a quick primer on the crank sensor and what it's used for (spark timing, perhaps?)
Old Mar 24, 2003 | 02:25 PM
dlq04's Avatar
Multi-port fuel injection system. Computer controlled direct ignition (no distributor) with a high-voltage coil for each platinum-tipped spark plug; controlled by sensors on the cams and crank.
Old Mar 24, 2003 | 04:34 PM
Yeah, the crank sensor is primarily for ignition while the cam sensors control fuel injection timing. His ignition timing was probably way off.
UL
Old Mar 25, 2003 | 06:02 AM
Insomniak's Avatar
so do u think damage was done.. probably drove it like that a total of 15 miles from the mechanic to my house.. then to honda. highest i got it was 3k.
