F20C1 converted to a F20C
Old Apr 18, 2006 | 11:45 PM
Trip's Avatar
Originally Posted by AusS2000,Apr 19 2006, 05:56 AM
Another JDM difference IIRC is a second knock sensor. Not surprising with the extra compression.
Good to know.
Old Apr 19, 2006 | 12:03 AM
jwkim's Avatar
Former Sponsor
N.A version is F20C1
CR ratio of 11.1:1
240hp
JDM/Euro version is F20C
CR ratio of 11.7:1 (different piston head design)
250hp.
I have also put dyno on N.A. S2k vs JDM S2k (both bone stock)
JDM version showed 8whp more on same dyno at same day.
MY03 N.A. = 205ps
MY00 JDM = 213ps
After dyno, we also had short rolling start runs and it was clear that JDM had more hp.
Old Apr 19, 2006 | 12:15 AM
jwkim's Avatar
Former Sponsor
To get back to the original question.
We have done JDM engine swap about 2 years ago.
and I remember it was pretty straight forward EXCEPT...
you have to transfer VTEC oil pressure sensor from your USDM engine to JDM engine.
Old Apr 19, 2006 | 12:25 AM
Trip's Avatar
CR ratio of 11.1:1
240hp
I believe there are only two types of CR 11:1 and 11.7:1. Never heard of 11.1:1
[B]JDM/Euro version is F20C
250hp.
My car is Euro spec and it is 11:1. Only JDM have an 11.7:1CR and yes, the pistons are the cause of the extra CR.
[QUOTE=jwkim,Apr 19 2006, 10:03 AM]I have also put dyno on N.A. S2k vs JDM S2k (both bone stock)
MY03 N.A. = 205ps
MY00 JDM = 213ps
Old Apr 19, 2006 | 12:33 AM
jwkim's Avatar
Former Sponsor
oops my mistake on "euro" and CR on USDM.
F22C USDM has 11.1:1
Old Apr 19, 2006 | 12:36 AM
AusS2000's Avatar
I was under the impression that the F20CX (where X is 1 or 2) were 11.1:1.
Old Apr 19, 2006 | 06:48 AM
Wisconsin S2k's Avatar
F20 in the US is 11:1
F22 in the US has 11.1:1
Old Apr 19, 2006 | 11:54 AM
s2kBryan916's Avatar
I would think they have different head gaskets to hold the higher compression?
Old Apr 19, 2006 | 12:57 PM
brent_strong's Avatar
There is only a single headgasket on the F20 series of engines and I guarantee it will hold anwhere between 11 and 12:1 compression ratios just fine. Probably a whole lot more (dynamic compression from a supercharger on a stock is a lot higher than an 11.7:1 engine). The gasket would be fine with so little extra compression.
Old Apr 19, 2006 | 09:38 PM
BigpoppaHurtm's Avatar
Then how do the JDM motors achieve the extra HP? Higher comp pistons?
