f22c and h22 similarities
Here is something Ultimate Lurker posted a long while ago briefly discussing the H22 vs the F20:
Actually, if you read Honda's own SAE article, their primary development comparison was the H22, which shares the same bore spacing and bore size as the F20C (and the exact same bore and stroke as the F22C). H22 cranks can be used in the F20C with minimal modification. The F20B does use a similar cylinder head to the H22 though, so simple conclusions are not easy to draw if you're not inside Honda
In reality, the F20C is really more of a evolutionary link between the H and the K-series engines, which shares much of the layout and technology of the F-series for use in a much wider set of applications.
UL
UL
