THE FAMOUS CHECK ENGINE LIGHT.
Old Dec 2, 2008 | 07:40 AM
jdmgpw04's Avatar
Default THE FAMOUS CHECK ENGINE LIGHT.
so anyways after filling up full tank of gas my check engine light came on after 6-7 miles of driving (solid light) anyways when i got home thought id check the gas cap to see if it was loose sure enough it was tight. so
my dumbass reset the ecu before i even got the code anyways i have been driving for 20 miles and still no light on.
does anyone know what else can cause this problem or is it just the gas cap that was probably a little loose?
thanks
sean
Old Dec 2, 2008 | 07:51 AM
dparm's Avatar
Mehh, I'd ignore it unless the light comes back. OBD2 is pretty sensitive.
Old Dec 2, 2008 | 08:10 AM
INDYMAC's Avatar
Gas cap. Turn until you hear at least 3 clicks and you're done.
Old Dec 2, 2008 | 08:14 AM
mlc's Avatar
mlc
Just an FYI the "gas cap" for lack of a better term code is P1456. Or that is what it is on an AP1.
Kevin
Old Dec 2, 2008 | 08:21 AM
jdmgpw04's Avatar
i always do, but for the first time in owning my 2004 s2 i have never gotten a check engine light before. My car is very well maintain so i was thinking that something else might have trigger it.
do you think i have a loose gas cap?
Old Dec 2, 2008 | 08:26 AM
mlc's Avatar
mlc
There was a TSB on the filler neck but that was for MY02 and early MY03. It could be a lot of things. If it comes back on just go to most auto parts stores and they can read it for you.
Kevin
Old Dec 2, 2008 | 09:45 AM
Slows2k's Avatar
Don't reset the PCM. Get the code, It COULD be anything...
Old Dec 2, 2008 | 09:47 AM
jdmgpw04's Avatar
ive read somewhere that even with a reset, the code will still be there? is that true?
Old Dec 2, 2008 | 03:06 PM
Slows2k's Avatar
No. If you disconnected the battery or removed the back-up fuse the codes are gone until the fault is present again. On some DTC's it will take multiple trips and driving cycles before it resets.
Old Dec 2, 2008 | 08:26 PM
S2Krazee's Avatar
I believe you mean "infamous". No one really likes CEL's.
RUINER831
Dec 11, 2010 09:31 PM
RASHID007
Mar 7, 2010 08:13 PM
Whitey_S2K
Sep 25, 2009 02:11 PM
mrs2k
Jul 15, 2003 07:41 PM
SLD2000
Oct 30, 2002 08:01 PM
