Check engine light cause by thermostat
Old Oct 30, 2002 | 06:52 PM
SLD2000's Avatar
Default Check engine light cause by thermostat
Anyone encounter the same problem as I do?
Old Oct 30, 2002 | 07:13 PM
speed4tu's Avatar
I don't see any way that changing a t-stat could trigger a CEL. Are you sure you did not pull a vacuum line or wire loose when changing the stat?
Old Oct 30, 2002 | 07:29 PM
SLD2000's Avatar
I don't think so, it was fine for 2 weeks after I installed the thermostat. The check engine light came up last week, I had it checked and light reset. The check engine light came up again today.
Old Oct 30, 2002 | 07:51 PM
GChambers's Avatar
Banned
Are you sure it isn't from the gas cap being loose? My gas cap turns half way on and starts clicking. The first few times I filled up the car, I didn't tighten it all the way. I have had my check engine light come on because of this. I have to really crank it to get it all the way on.
Old Oct 30, 2002 | 08:01 PM
SLD2000's Avatar
I'm pretty sure it is not the gas cap because I had my car checked twice in Honda, the conclusion is cooling system problem especially the thermostat.
RASHID007
Mar 7, 2010 08:13 PM
Whitey_S2K
Sep 25, 2009 02:11 PM
jdmgpw04
Dec 2, 2008 08:26 PM
Sumo801
Jul 16, 2002 11:59 AM
yogi
Nov 6, 2000 04:24 PM
