Feedback on Amsoil 75W-110 Diff oil
Old Aug 30, 2010 | 10:30 AM
bd307's Avatar
Default Feedback on Amsoil 75W-110 Diff oil
Anyone have feedback on the Amsoil Severe diff oil 75W-110?
This is the product by HTG.
http://www.hardtopguy.com/store/product.ph...64&cat=0&page=1
I want to go with LE1605, but I can't find anyone selling locally in Socal.
Old Aug 30, 2010 | 11:05 AM
afzan's Avatar
I'm using it, can't really tell any difference to before to be honest.
A 75w110 matches the old SAE 90 spec that Honda specifies for our cars better than a modern 75w90 does, so IMO you can't go wrong with it.
Old Aug 30, 2010 | 11:07 AM
wisdom's Avatar
I run Amsoil 75w-110 in my diff. So far so good. You can try seaching for an oil analysis, or jump on BITOG. But from my experience Amsoil always have great products and positive reviews.
Let me know if you need a quart, I have some.
Old Aug 30, 2010 | 12:21 PM
Swift GT's Avatar
Is there any issue with running the 75w90? That's what I have in my diff.
Old Aug 30, 2010 | 12:25 PM
spets's Avatar
Lots of people run that without issues. But next time I'd get the 110 weight.
Old Aug 30, 2010 | 04:03 PM
zeroptzero's Avatar
that's it exactly.
I hope to have a used fluid analysis of mine in a month or so. The LE fluid is a great fluid as well. If you use your car in cold temps the Amsoil may be slightly better as it is 100 percent synthetic and will flow better in cold temps while protecting equally well in hot temps.
Old Aug 30, 2010 | 04:33 PM
AP2Berlina's Avatar
yeah i just used mobil 1 75-90 based on what others said on here..so hopefully thats fine
Old Aug 30, 2010 | 05:02 PM
afzan's Avatar
[QUOTE=JFUSION,Aug 30 2010, 08:03 PM]
Old Aug 30, 2010 | 05:40 PM
zeroptzero's Avatar
[QUOTE=afzan,Aug 30 2010, 09:02 PM] Haha, it was one of your posts in a 'what diff oil should i use' threads that got me researching the 75w110
Old Aug 31, 2010 | 04:11 AM
slipstream444's Avatar
The Amsoil SG75W110 is currently the best gear oil on the market and is perfect for all temperatures in the S2000.
I don't see a problem with running the SG75W90 - especially in the colder months. The diff typically doesn't get hot enough in normal driving in cold temps to worry about using 75W110. There's nothing wrong with running it in summer temps for normal to spirited driving - you actually might see slightly better fuel mileage. However, I don't recommend it for extended track use. 75W110 or 75W140 (modified diffs) for anything greater than spirited driving - especially in the hottest months.
I've used the LE fluids and frankly wasn't impressed - especially when it came time to change the fluid - it always came out very dark. I've gone more than 15,000 miles with Amsoil SG (and the Series 2000 gear oils that preceded it) and it comes out almost the same color as it went in - clean and very little deposits on the mag plug - the lightest of smears when the mag plug was cleaned. The two times I used LE, the plug came out filthy with significant fuzz (not just a smear) and the gear oil was like crude. That doesn't give me confidence in LE fluids.
Clean and consistent color = low wear and normal temps.
Additionally, I haven't seen anything but an outstanding UOA on any Amsoil product to date.
The Mobil 1 75W90 is a decent gear oil (doesn't test out as well as Amsoil - but it took a distant 2nd place) and would be the gear oil I'd use if I ran into an emergency where I couldn't get my hands on Amsoil (although I always have spare Amsoil on the shelf). Mobil 1 is available at any parts store and Walmart. If you want the best - stick with Amsoil.
A test commissioned by Amsoil through an independent lab:
http://www.amsoil.com/lit/g2457.pdf
It shows that you can't measure a lubricant on only one characteristic. The best fluids do well in every industry standardized test.
BTW - the worst fluids in this test were Lucas, one of the MOPAR synthetics and Royal Purple.
