Fender Liner Drooping
Old Apr 21, 2006 | 03:01 PM
superjimbo's Avatar
Default Fender Liner Drooping
Hey All,
My driver's side plastic fender liner appears to be drooping a little. It looks like one of the plastic snaps isn't fitting properly. Anyone know what part number this is? Also, how do I remove the old one and install the new one? Thanks!
Old Apr 21, 2006 | 03:04 PM
TR-S2K's Avatar
Your car is 2005, dealer should fix it for you under warranty if your car is less than 36k miles.
Old Apr 21, 2006 | 03:11 PM
superjimbo's Avatar
Unfortunately, the car was in a minor accident and had some body work done around that area. So more than likely, the dealership will not replace it under warranty. Besides, I would rather do it myself
So with that said, can anyone help me out? Some pics would be mighty appreciated too
Old Apr 21, 2006 | 04:08 PM
SIIK2NR's Avatar
You need an inner fender liner clip and they sell them on HandAaccessories.
http://www.handaaccessories.com/s2000-04.html
Old Apr 21, 2006 | 04:24 PM
superjimbo's Avatar
Thanks SIIK2NR - that's the piece I need! How do I remove the old one and install the new one? Does it just pop out or is there another way? Thanks!
Old Apr 21, 2006 | 04:48 PM
Yflyer's Avatar
No offense to H and A, but these clips are cheap and available at your local Honda dealer. Avoid the shipping costs. To remove them, you insert a small flat blade screwdriver into the little slot in the clip and it will pop open. To insert, just push tem in , and then push in the center protion to lock it in place. Ask the parts guy to show you this when you buy them. These clips are common to all Honda's and they seem to disappear at random.. I keep a few extras at home since I own five Honda's.
Old Apr 21, 2006 | 05:07 PM
LubedKoala's Avatar
After I had a new fender installed the plastic lining on my car was also a little off. I just used a hair dryer and heated up the plastic, shaped it and let it cool down real quick. It's "cheek-to-cheek" with my fender now. FYI
Old Apr 21, 2006 | 05:10 PM
John_Z's Avatar
You can tuck the fender liner on top of the metal fender tabs instead of using the clips.
Old Apr 21, 2006 | 09:17 PM
TR-S2K's Avatar
Originally Posted by superjimbo,Apr 21 2006, 04:11 PM
Unfortunately, the car was in a minor accident and had some body work done around that area...
I didn't know that. Sorry for bad comment
maomaolong
Jun 8, 2016 09:52 PM
Keith P
Mar 29, 2014 05:46 AM
tharza469
Aug 7, 2009 01:46 PM
villain2000
Sep 16, 2004 02:30 PM
RobC2
Nov 15, 2003 02:02 PM
